Shopping list - Page 4 - TCCoA Forums
post #91 of 98 (permalink) Old 10-22-2015, 08:56 AM Thread Starter
ROLLINTHUNDER's Avatar
Hey, since we've covered most of the basis when it comes to a M5R2 swap, would this thread make a good sticky for the next guy?
Eibach pro kit springs w/rear cobra bilstiens, rear disc conversion, 2000 Cobra R wheels, 89 SC track-lock swap w/mark 8 cv shafts, 89 front and rear sway bars
ROLLINTHUNDER is offline
post #92 of 98 (permalink) Old 10-30-2015, 09:44 AM Thread Starter
Well ive come to the conclusion that the 1st and 2nd gear synchros are out. 3rd 4th and 5th are perfect. 1st and 2nd you cannot downshift into while the car is moving. It has to be completly stopped. I can take off in both gears but I cant upshift into second when the car is moving. I go from 1st right to 3rd, which its geared so close and with the 3.27's I can do that.
post #93 of 98 (permalink) Old 10-30-2015, 12:10 PM
Even with shot synchros, you should be able to shift from 1st to 2nd, it will just grind a little. If you can't shift into 2nd at all when moving, then you might have a bigger problem.
post #94 of 98 (permalink) Old 10-30-2015, 01:35 PM
Slightly Disjointed
Have you tried double clutching? My TR3650 gives some resistance on a second to first downshift at speed, I double clutch and rev match though it's smooth as butter.
post #95 of 98 (permalink) Old 10-30-2015, 03:29 PM Thread Starter
Havnt tried double clutching yet. I will try that tomorrow. Thanks guys!
post #96 of 98 (permalink) Old 08-24-2016, 08:52 AM Thread Starter
I'm thinking on trying to order a trans from work how it seems I can get a rebuilt one for bout the same price as getting this one rebuilt. Does anyone know the part numbers and/or serial number I need to look for to get a 94/95 M5R2 to get the better gearing? Thanks guys.
post #97 of 98 (permalink) Old 08-24-2016, 09:28 AM
jco1385's Avatar
1989-1993 m5r2 = e9sr-ab-rke-aa1
1994-1995 m5r2 = f4sr-aa-rke-ab
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #98 of 98 (permalink) Old 08-24-2016, 02:03 PM Thread Starter
Thank you
