How Do I Replace CV Joint Bearings Inside the Diff? - TCCoA Forums
post #1 of 9 (permalink) Old 01-11-2017, 03:42 AM Thread Starter
I have a 97 lx and my right side CV joint seems to wiggle where it goes into the differential. I believe this is why I have a vibration at 70 mph only on the right side. I've ruled everything else out.
I think I can remove one upper control arm bolt, lean the spindle outward and pop the axle out of the diff. There is a seal which should be easy to remove and a bearing behind it which appears to pop out like the seal does. I'm guessing it's pressed in?
Has anyone replaced these bearings before?
They don't come out through the inside of the diff, do they?
If they come out from the outside, do you use a bearing puller with slide hammer and pop it loose just like a pilot bushing in an engine?
JasonWW is offline
post #2 of 9 (permalink) Old 01-11-2017, 12:21 PM
Here's a pic of the inside posted by Rayo that clearly shows the bearing caps, inside the diff.
You could probably pull them out the side, but I doubt it will be reassemble-able later.
It has to come off, be taken apart, and rebuilt; most likely.
All the pieces of that bearing ate in there somewhere, and I have yet to take one apart that still has the brass shims intact; they're usually smeared throughout the gearset.
Pulling it isn't too bad; one suspension side off is fine.
Just unbolt the DS (12mm bolts), and unbolt the assembly and pull toward the side that's off, the other side pops right out with a screwdriver.
The old grease is the worst part...
post #3 of 9 (permalink) Old 01-11-2017, 07:36 PM Thread Starter
I saw on an explorer diff that the bearings can be pulled out the side. You pry the seal off then use a 2 finger slide hammer to carefully pop the bearing out. Putting a new one back in is easy, you just tap it in using a large socket.
I assume the t-bird diff are built the same way. They look the same internally at least.
It also occurs to me that the bearings might be fine and it's the cv joint shaft that that rides on the bearing that has worn down. I'm just gonna have to pull the axle out and take a good look.
You can see the bearings in the picture below.
JasonWW is offline
post #4 of 9 (permalink) Old 01-11-2017, 08:01 PM
Those bearings are easily replaceable without disassembly of the diff. It's just like replacement on a solid axle 8.8".
rodsv6cougar@cs.com
post #5 of 9 (permalink) Old 01-11-2017, 08:10 PM
So there's two sets back to back?
post #6 of 9 (permalink) Old 01-11-2017, 08:19 PM
Rayo's Avatar
The Pilot Bearings that the CV shaft rides on are removable, if that's your problem..
I have removed a couple sets, and depending on the age/wear/condition of the Pilot Bearings..
They can give you trouble trying to remove them without damaging something else in the process..
I wouldn't call it an easy job..
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 9 (permalink) Old 01-11-2017, 08:21 PM Thread Starter
Thanks. Easily replaceable is what I wanted to hear.
I think you were describing the big bearings the carrier rotated on. I was talking about the bearings the cv joint rode on.
Awe, man.
JasonWW is offline
post #8 of 9 (permalink) Old 01-11-2017, 08:34 PM
I just looked at the exploded view drawing; I see my mistake.
There can't be just one set there, it wouldn't rotate, lol.
Sorry.
It should tap right out with a slide hammer; if you have the whole thing apart, you drive it from the opposite side.
Be really careful what you do with the used oil from the diff; it defines nasty smelling grease, lol.
Nothing outstinks used gear oil.
post #9 of 9 (permalink) Old 01-12-2017, 08:10 AM
T6Rocket's Avatar
How about the LSD additive from 30 years ago, when they used to make it from whale oil? I know the Mopar stuff was beyond disgusting.
Al
97 T-Bird LX 4.6 - 66k miles
Previous cars:
T6Rocket is offline
