Help me on TC info, I may get one - TCCoA Forums
post #1 of 6 (permalink) Old 03-05-2017, 07:47 AM Thread Starter
94badbird's Avatar
I want few more mods , will I need a tune after a higher stall tc? The one Im interested in i linked below.
http://m.ebay.com/itm/Ford-High-Stall-Torque-Converter-AODE-4R70W-2300-2500-Performance-Lockup-/232036872702?nav=WATCHING_ACTIVE
94badbird is offline
post #2 of 6 (permalink) Old 03-05-2017, 08:10 AM
Woodman's Avatar
Ford High Stall Torque Converter AODE / 4R70W 2300-2500 Performance Lockup | eBay
That's not far off the mark from stock. I believe the Mark VIII/Cobra/Marauder TC are in the 2800 stall range, and a 3200 to 3500 stall really wake these up. If you want to go inexpensive, get one for a Mark VIII/Cobra/Marauder as they are the smaller diameter unit so they don't balloon at high RPM, and they have a good, slightly higher stall to help get you moving. Next up would be a good circle D unit, but they're in the $700 or so range.
Woodman is offline
post #3 of 6 (permalink) Old 03-05-2017, 02:34 PM
I picked up a 2800 stall TC from dirtydog in the $400-$500 range (don't remember exact amount). If all your doing is swapping out the TC and nothing else (i.e. rear diff gears, tranny, etc.) then you don't "need" a tune. Once you start stacking up the upgrades then it would be worth a tune.
Black '96 TBird - Dynotech 3.5" MMX DS, SCP mounts and brackets, Art Carr 4R70W transmission, DirtyDog 2800 stall TC, true dual exhaust w/FlowMonster mufflers, 3.73 gears
lurch is offline
post #4 of 6 (permalink) Old 03-05-2017, 03:07 PM Thread Starter
94badbird's Avatar
I do want good driveability not just a launcher ...
I shall go look for marauder tc.what is the exact stall on those ?
Isn't stock stall on my 94 like 1200-1600 only,if so that ebay one I think id like it its a direct bolt in.
post #5 of 6 (permalink) Old 03-05-2017, 03:26 PM
Woodman's Avatar
What size is it?
If it's the stock 11" size, it will still have issues with high RPM where it will balloon. The ad was somewhat vague.
If you want just a mild bump, go Mark VIII/Cobra/Mach1/Marauder. They're all the same converter, but because they're on an engine that revs to 6000+, they're the smaller diameter and won't balloon.
Woodman is offline
post #6 of 6 (permalink) Old 03-06-2017, 09:12 AM
r429460's Avatar
I have a 3000 stall converter, if you are interested.
$150, its a Dirty Dog converter.
Rick
PS: you'd need a different flex plate.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
HTML code is Off
