Help - Addco 1-3/8 front bar install - TCCoA Forums
post #1 of 10 (permalink) Old 04-14-2013, 07:03 PM Thread Starter
95_SilverBird's Avatar
Send a message via AIM to 95_SilverBird
I'm putting in the front bar (finally) along with some other maintenance. It just touches the abs sensor bracket at the bumpstops on each side. I'm ok with that as its only under full lock, and tells me I def have the bar centered.
The problem I ran into is when re-installing the pass motor mount, I lower the motor and the addco bar hits the ac compressor not allowing the motor to fully seat.
The car has eibach springs and DLF poly motor mounts. I don't think they should matter.
I also tried lifting the wheel thinking that it the suspension is to relaxed on the lift but a jack just raises the whole car now.. haha. That and I'm not really comfortable with that hitting at any point.
Anyone else run into this??
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #2 of 10 (permalink) Old 04-24-2013, 11:29 AM Thread Starter
Ended up chaulking most of it up to body flex as it was on jack stands behind the front wheels. I did remove one of the spacers and ground a half moon out of the lock collar. Seems to rotate good and just clears by a hair when on t he stands. Of course it's great driving
post #3 of 10 (permalink) Old 07-06-2013, 10:38 AM
im going to do that sway bar size also
I was wondering how difficult it was to put the sway bars is? I heard the back aint that bad but the front is hard.
rviera5 is offline
post #4 of 10 (permalink) Old 07-07-2013, 11:13 AM Thread Starter
The front really is a pita. Have to support the engine from the top and drop the kmember
post #5 of 10 (permalink) Old 07-24-2013, 09:36 PM
MaleWhore
smokymance's Avatar
thats not what i wanted to hear...
do the swaybars follow the "bigger is better" moto?
1997 MN12 Sport 4.6L Supercharged 5 Speed
2000 Jeep XJ 4.0L Lifted
smokymance is offline
post #6 of 10 (permalink) Old 07-24-2013, 10:38 PM
It depends.
Bigger reduces sway, but can have other considerations.
You get big enough, might as well weld the LCA/frame bushings solid *grins*
RalphP is offline
post #7 of 10 (permalink) Old 07-24-2013, 11:10 PM
CDsDontBurn's Avatar
Question about Sway Bars in general.
A thicker Rear SB will cause more oversteer and a thicker Front SB will cause understeer. Since our cars are RWD, why would having a thicker RSB be more beneficial over having a thicker FSB?
CDsDontBurn is offline
post #8 of 10 (permalink) Old 07-24-2013, 11:21 PM
Custom User Title
It would be ideal to match the sway bar size front and rear.
dDUBb is offline
post #9 of 10 (permalink) Old 08-04-2013, 10:24 PM Thread Starter
After running this for a while I may look into moving down to the 1-1/4" These give almost no body roll, but I think there was a better 'feel' for the road with the stock bars...
post #10 of 10 (permalink) Old 07-02-2015, 09:09 PM
I will never try to install a front sway bar on a Tbird.
I will put a fat one in when the motor gets swapped.
Old Skule is offline
