Hmm wonder what's up - Page 2 - TCCoA Forums
post #31 of 42 (permalink) Old 05-29-2013, 08:22 PM
The Great Obucina's Avatar
Originally Posted by ThunderChecken View Post
Forgive me for even starting this thread , The wife is in the market for a Ecoboost and we were just wondering about the issues .
my mom has had her Escape for almost two weeks and loves it! SE model with the MyTouch stereo and 2.0L motor, its a lot of fun to drive.
"Booyah". Stu Scott.
1996 Braincoated, all Aluminum PI powered and obscenely loud Pearl White Tbird 14.17@98.57mph AKA Dyrdek.
The Great Obucina is offline
post #32 of 42 (permalink) Old 05-29-2013, 09:30 PM
I had to go to a class for direct injection vehicles and problems associated with it. They were saying you have to take care to clean the valves more frequently, since the injector does not spray on the valves. Well, the spray in the intake, but it still hits the valve to clean in it. DI sprays in the cylinder so carbon will build up on the valve causing rough idle and miss fire. They said so far there was no easy way to clean them. They told us the dealerships are havering to pull intake manifolds off and us a wooded pick and knock off the carbon by hand. Some cars as low as 10K miles.
lcortinas is offline
post #33 of 42 (permalink) Old 05-29-2013, 09:35 PM
Rbrown the hiccup was a plug breaking down under boost I went thru this after adding my blower 10 years ago I thought hey this thing is fast then about 10k miles later its got a slight hesitation hmm must be bad wires nope finally I pulled plugs looked great swap in a new set perfect, so we put old plugs in buddy's car and it ran perfect, what this told me is a boosted setup the plugs must be perfect we're as the old plugs worked great on a all motor setup, I was not happy at first but learned that was the downfall to boost
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 6.34@109.89
10.11 @ 139.19 best mph
RobertP is offline
post #34 of 42 (permalink) Old 05-29-2013, 10:11 PM
rbrown's Avatar
It sounded like it misfired in the intake and broke a rod. It was loud.
And there was no throttle response right after. Like it had to re-group for a minute after that. lol
I have had fuel pump issues though. It has cracked 3 top hats.
It is fun. I like spanking people in a 5000# vehicle with 4 people in it.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #35 of 42 (permalink) Old 05-30-2013, 07:23 AM
It's a bad a$$ motor people don't realize the difference with boost it makes a small motor a monster
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #36 of 42 (permalink) Old 06-12-2013, 10:24 PM
Torinocator's Avatar
NHTSA says Ford told dealers how to fix the issue but hasn't alerted owners.
Regardless of the cause, this means that Ford has acknowledged that there's a problem.
Misfiring during a pass, especially if you are the leader and there are one or more cars behind you, is some scary stuff on a two-lane blacktop.
Does the misfire automatically trigger the "limp mode" on the ECM? Maybe Ford just needs to modify the code to not stay in limp mode for so long.
Use a tool, don't be one...
-Mark
1997 Thunderbird LX 4.6L
1970 Torino GT 351C 4V
...................................GT
Torinocator is offline
post #37 of 42 (permalink) Old 06-13-2013, 07:24 AM
Well look here last I read u are not suppose to pass until the front car is already around, the truck still accelerates in limp mode I've drove one its just not balls to the wall power but its as good as any normal vehicle
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #38 of 42 (permalink) Old 06-13-2013, 07:39 AM
Well look here last I read u are not suppose to pass until the front car is already around, the truck still accelerates in limp mode. I've [driven] one, it's just not balls to the wall power but it's as good as any normal vehicle.
That's the truth! ~Drivers ED. 101.
Never start a pass until you're certain you can complete it; and if that's dependant on the guy in front of you getting around first then you shouldn't be attempting the pass.
post #39 of 42 (permalink) Old 06-13-2013, 08:39 AM
That's what I was thinking I believe the issue is the driver is used to all the extra power that a truck doesn't normally have and one hiccup and there freaking out, guys I've got a 05 5.4 3v with tune exhaust and intake and its no slouch but a bone stock ecoboost is a 14 sec track in any cab configuration u want so that's very strong, as we like to say around here u can't have everything
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #40 of 42 (permalink) Old 06-13-2013, 09:12 AM
rbrown's Avatar
No. My Flex has gone into limp mode and it will not drive like a normal car. Think more in line with the brakes full on and you trying to drive. It moves but barely.
Possibly there is more than one "limp mode" and some are more severe. When mine happened it was to protect the Advance Trac. A little wrench shows on the dash. Simply turning off the vehicle (not easily done in traffic) reset the problem.
*Rodney*
rbrown is offline
post #41 of 42 (permalink) Old 06-13-2013, 11:01 AM
Yes the advancetrac cuts it way back that's different it's to protect the awd system the misfire limp mode just reduced the power on the 2011 I drove
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #42 of 42 (permalink) Old 06-14-2013, 12:13 AM
Mgino96tbird46's Avatar
It'll be interesting to see what the cause of all this stuff is.
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
HTML code is Off
