Tech Article: The definitive PI intake swap - TCCoA Forums
post #1 of 1 (permalink) Old 04-06-2013, 03:06 PM Thread Starter
Technical Administrator
Heads and intake swap 98GT on a 94 4.6
PI intake swap from '94-'95 Cruise control cable issue
Oh No!! Another head/intake swap question
PI intake swap problem
Just finished the PI intake to NPI heads swap. Questions and results
PI Intake swap idea
just some details on the PI intake swap...
Actual gains from the PI intake swap?
PI head/intake swap: Which chip?
PI Intake/cam swap dyno results
Dyno results - Cougar intake swap
4.6 Intake Manifold swap
PI intake swap.. water pump nipple..
couldn't find the PI intake swap article, where is it listed?
PI Intake swap.. small idle issue?
It's here!!!! PI intake swap article for 94/5
PI intake swap article Part 2
pi intake swap
The PI intake swap
pi intake swap help
PI intake swap and T-bird waterneck?..
Fuel Lines/Intake Swap ?'s
PI intake swap Kit
PI Intake to Non PI Head swap ?'s
fastest possible w/o PI head/intake swap
crank no start after PI intake swap/ran fine after
PI intake swap
Intake Swap
pi cam and intake swap
pros and cons to PI swap vs PI intake and cams
Livernois PI Intake Swap "kit"
PI Intake Swap Nightmare
What parts do I need for the PI intake swap?
bullitt intake swap egr tube
PI intake swap... I have the parts... now what?
Running weird after intake manifold swap
PI Intake swap question
Composite intake swap
High Idle after Intake Manifold Swap
1995 Thunderbird LX PI Intake Swap and CAI
PI Intake & Cylinder Head Swap Info Needed
Ford Non-PI Intake Swap
Just pi cams and intake swap any luck?
PI intake swap
Non-PI Intake Swap/Water Pump Question
Finishing up PI Intake swap and COP conversion.
Semi-Auto climate PI intake swap help
94-95 to 96-97 intake swap parts needed
intake swap
1995 to PI Intake Swap
PI intake/cam swap or DOHC
Use NPI or PI gaskets on PI Intake Manifold swap?
PI Intake Swap (Heater Hose and Nipple)
PI Intake Swap Pics
PI Intake Swap- Do I need this hose?
CRUISE CONTROL after INTAKE SWAP
After PI Intake swap question
PI Intake swap on 96 XR7
PI-Intake on a '94/'95 4.6
If you still can't manage to properly do a PI intake swap, you have no business wrenching on these cars
Technical Administrator is offline
