Installing the Lightning 80mm MAF - TCCoA Forums
post #1 of 1 (permalink) Old 10-28-2007, 07:15 AM Thread Starter
Technical Administrator
Parts needed:
• MAF Part Number is: XL3Z-12B579-AA ($120 or so)
• Wire Harness Part #: F68Z-12A690-AA ($15)
• New harness (only for 89-95s)
• Adapter for the air filter
• New chip that will utilize increased airflow
The 80MM Lightning MAF is the stock sensor on the 5.4L F150 Lighting from '99-'00. It uses a unique sample tube setup which allows for more accurate airflow measurement while expanding its dynamic measurement range for its supercharged application. Having said that, it is also a very good value when considering a MAF upgrade for 70MM units(or smaller) on a limited budget. List price on 6-2-2000 was $147.73. Discounted from your favorite dealer it can be relatively cheap.
YOU MUST have the transfer function of the Lightning MAF put on your EEC/PCM/CHIP for proper air/fuel ratio and engine function. It is not just a hardware swap.
This is the inlet side view of the Lightning MAF (L-MAF), Ford PN XL3Z-12B579-AA. It uses a flange mount on the front which is the standard flange for F150/F250 and 4.6L Mustang airboxes. Adapters can be purchased to allow for large open cone filter attachment. These are the only mounting points so be prepared to come up with something to hold it. The bore of the MAF is actually smaller than some other MAFs, but it is venturi shaped to control air velocity tighter.
Note on filter configuration. The stock configuration has air entering this meter from a cone shaped filter that is centered on its bore. Changing the airstream dynamics can affect the meter's accuracy, so stick with the factory configuration. Likewise, since it is configured like this from the factory, it is the best meter, with few if any exceptions for open filter setups that employ factory hardware.
This shot is a back to back comparison of the outlets of the L-MAF on the left and the stock 70MM MAF used on my '95 Thunderbird. The outside diameter of the L-MAF exit is about 3.6" or about 90MM. A 3.5" silicone hose fits very snug over it.
Here is the L-MAF attached to a Mustang Style K&N filter. I used a piece of aluminum plate and made all the holes to glue and screw it together. The wiring harness shown is a must-have. The connector on the L-MAF is the late model style. Use F68Z-12A690-AA wire assembly and cut off the other end to allow it to be spliced into the stock wiring. The wiring pinouts match the stock, A to A , B to B, C to C, D to D.
A hint: To attach the L-MAF to a stock T-Bird airtube to the TB, you will need to adapt from 3.5" to 3". Otherwise, you can get a custom intake tube and use the TB boot off the stock airtube(violin case) to attach reversed to the L-MAF and provides a 3" outlet connection. Then you can use the port from the idle air bypass to insert the intake air temperature sensor into the airstream.
Technical Administrator is offline
