#91 | |
The AFDB is on a lil tight. Join Date: Mar 2007
Car: 1994 Thunderbird LX
Rolling a built rear end,trans/tc,and a tune. Stock 4.6 Engine |
#92 |
Car: 1992 Cougar
Engine: 3.8
Had a annoying groaning from the front end every time I went over even the smallest bumps. Chased it for almost a year before I finally found cracks near the rear wheel wells and a broken V brace at the back seat. Put in L brace to stiffen it up some and the front end groaning went completely away. Gonna reinforce the heck out of it to keep in from braking loose again. Little bit too much body flexing.
1992 Cougar 3.8 Air Silencer Delete Electric Fan 130 amp alt in process or Mark VIII interior swap. |
#93 |
Car: 1997 LX
Engine: 4.6L
Ball Joint Failures
My daughter's 97 TBird just broke the passenger side lower ball joint. Fortunately the joint broke on a driveway entrance to a strip mall rather than on the freeway at speed. The tow truck driver said he sees allot of these birds with broken ball joints and it often is not a pretty site when they break on the major highways.
Her car has about 135K on it with very easy driving, so I would strongly recommend that anyone with one of these birds replace the lower ball joints automatically at 100K miles or you might just be killed. My wife drives another 97 Bird with allot fewer miles on it. About 40K. So when it hits 100K, I will change the ball joints regardless. Phil Swanson
Bluebird |
#94 |
Banned
Things to check if you hear clunking from your suspension
Im going to drop my truck and I will soon need new shocks upfront. Maybe your stock shocks are bottoming out? I can sell you my stock ones. I can trade them in and get new ones from my warranty.
#95 | |
Car: 1993 LX
Engine: 3.8
The 6 point 14 mm worked just fine to check these bolts. ![]() So that wasn't the reason I get a popping noise while hard braking and turning to the right....got it narrowed down to either the torsion rod bushing or rack and pinion.
'93 T-Bird 3.8 bone stock with 17" Cobra R rims and Bridgestone Potenza Tires. |
#96 | |
Mr. Smartypants
Car: 1996 Thunderbird
Engine: 4.6L NPI
My dad's 95 T-Bird developed an annoying clunking, rattle that was most noticeable at 40 mph on fairly smooth roads.We kept looking for something obviously loose, but found nothing. Finally, he raised the car and hit the center of the sway bar with the heel of his hand. A click came from the left sway bar end link ball joint. The original end links have ball joints with no lubrication grease fittings. The grease dried out years ago and the lower ball had developed about 1/16th of an inch of play in the dry socket. That small amount of play let the clunk vibrate through the whole sway bar and drive him crazy. He replaced the sway bar end links and the clunking rattle is gone. The replacement links (buy 2 at $30 each)have ball sockets with a grease fitting. It took quite a bit of grease to fill the new sockets and the new cup. We also lubed the lower ball joints at the same time. Replacing the sway bar end links is not hard, but also buy a grease gun to lube up the new ball sockets. After taking off the 15mm nut, the post had to be hammered to pop out. Since there is no tension on the sway bar, the new links went on easily. Thanks for the suggestions listed below.
96 Laser Red 4.6L - Custom Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge |
#97 | |
Car: 1997 Thunderbird
Engine: 4.6L
~97 4.6 LX SPORT ~ LOWERED ~ 143K MILES ~ K&N ~ JMOD ~ XCAL TUNED BY LONNIE ~ 3.73 FRPP ~ POLYURETHANE FRONT SUSPENSION BUSHING ~ 4300K PROJECTOR'S ~ Last edited by KorpseofDeath : 10-01-2009 at 11:40 PM. |
#98 |
Car: 1997 Thunderbird LX
Engine: 3.8
what kind of carnage did that create?
#99 |
Engine: 4.6L
Well, the lower ball joint completely came out of it's socket, so it's just the upper control arm and the rack and pinion steering arm holding it together, to the car instantly drops down and the tire back towards the passenger. I pulled in the center and got out expecting it to be a flat tire, and then saw my whole front end dropped about 2 inches, was like f*%*k!!!! I then had to get CHP to traffic break me to the next exit. Driving at a slow less than 10 MPH, just listening to me tearing my tire apart on the way. Finally got to a place where Tow Truck can pick me up, got it home, and on the tow truck it completely gave way, and my front end was laying on the ground.
The driver was very good and experienced. He backed up into my driveway, and I had to drag my front end off the tow truck, but left the front wheels on the tow truck, then he lifted it with the truck, and we placed jacks under it. That was really relieving, because if the car was to just be dropped, there would be NO complete way to get a jack under my car, Literally! Thankfully it happened at 60MPH, hardy any traffic, and hardly any damage. Just gotta get a new tire, and see if the rim is salvageable, it took a good scraping on the inside, but I think a re-balance and it should be ok and work with the inner fender and such where the tire rubbed, and now dread the $700. in the suspension rebuilt, which I was still in the process of saving up for! lol
~97 4.6 LX SPORT ~ LOWERED ~ 143K MILES ~ K&N ~ JMOD ~ XCAL TUNED BY LONNIE ~ 3.73 FRPP ~ POLYURETHANE FRONT SUSPENSION BUSHING ~ 4300K PROJECTOR'S ~ |
#100 | |
Dennis |
#101 |
Engine: 4.6L
Yes I am. I'm purchasing the High Performance Polyurethane Front Suspension Bushing Kit from sc performance, and getting the moog control arms, basicly all high quality parts, don't go cheap on suspension, i've learned.
#102 |
I've got a bad case of the clunks right now too. I've got brand new UCA's on both sides, Brand new Sway bar end links on both sides, brand new KONI shocks / Vogtland 1.6" drop springs, and a brand new LCA on the left and the knock is STILL there....when I replaced the UCA on the left I noticed the bushings were pretty mashed but I didn't think much of it, so I'm assuming that it's either the Strut rod bushings into the LCA or Tie Rod End or K-Frame bolts.....anything else I could check? I highly doubt it's the Steering Rack
1995 Mercury Cougar XR-7 ![]() a.k.a 1BadCat -Spectre Air Intake Filter -Air Silencer Delete -Bosch Platinum +2 Spark Plugs -KONI Infinitely Adjustable Gas Shocks All around -Vogtland 1.6" Lowering springs Last edited by '95Cougar_XR-7 : 12-04-2009 at 07:27 PM. |
#103 |
TCCoA Member
Car: 1995 Thunderbird
Engine: 4.6L
My clunk story
Ok, I guess I'll tell my clunking story. First thing, I had a lot of clunking from back, got it up on a lift and saw the sway bar links broken on both sides - replaced. All KINDS of noises from front, so I change Upper Control Arms, Lower Ball Joints, Sway Bar Links. I STILL have a dry rub noise from passenger front. Get it on lift and start moving stuff. In the back I see movements and replace Outer AND Inner Upper Control Arm bushings, and the Outer Lower bushings. Didn't fix the noise in the front?!? Go figure!
Anyways, got it lined up and all went well EXCEPT the tech can't get the passenger rear tire to stand straight up, it's half a degree off - you can't hardly see it but I guess something is tweaked back there - maybe the car slid sideways toward the passenger side before I got it. I figure I'll just put the upper control arm in the press at work, and crush it about 1/4 of an inch or so to add that negative camber. What could be causing the noise on the passenger side front? I can push the fender down and make it squeek, and it sounds like it's coming from the UCA. I tried spraying WD-40 on the bushings, didn't help. Could I have gotten a bad upper control arm new? Could it be spring mount at the top? |
#104 | |
No more broken boots!
1995 Mercury Cougar XR-7 ![]() a.k.a 1BadCat -Spectre Air Intake Filter -Air Silencer Delete -Bosch Platinum +2 Spark Plugs -KONI Infinitely Adjustable Gas Shocks All around -Vogtland 1.6" Lowering springs |
#105 | |
Car: 91 Tbird LX
Engine: 3.8L
when do you hear this rub? when you turn the wheel? Could be tie rod ends.
91 3.8L LX 95 4.6L LX 40th Ann. |
#106 |
Also just because some one said something about clunking when hitting the gas. Check the engine mounts. I'm having the same clunking problem and it was my drivers side engine mount. It turned out to be that 1 of the bolts came out causing the head on the second bolt to be sheered off. So when I nail the gas the engine lifts up on the drivers side and when I let off it slams back down. Not good... Also had a bad upper control arm bushing, broken spring and strut all on the passengers side. Also not good.
Last edited by 92Thunderchicken : 05-23-2010 at 11:26 PM. Reason: control arm bushing was bad not ball joint |
#107 | |
TCCoA Member
Engine: 4.6L
Hope everyone had a good weekend! |
#108 |
Engine: 4.6L V8
Hey all,
Is this the type of clunking sound an end link would make?: http://www.youtube.com/watch?v=GdZqbLPBZv0 I've taken a rubber mallet to everything under there, but the sound only shows up when driving. It's kind of driving me mad! ![]() |
#109 |
Car: 1997 LX
Engine: 4.6L
Sub Frame Bolts
After working on many of these Thunderbirds/Cougars, I have found that 90% of them are clunking because of loose sub frame bolts. Get a large Torx head socket and tighten them up to 100 ft pounds. I have seen some as loose as two turns backed off. The clunk is comming from the whole front frame moving as you brake or corner. Not the only culpret but it should be eliminated first because it is so common in these cars.
Phil Swanson (2) 97 T Birds
Bluebird |
#110 | |
Car: 1996 Bird
Engine: 4.6 V-8
Any determination on this noise, Lime? my 96 Bird is making the same exact rattle/clunking as was heard in the Vid.
1988 Bird 3.8 1996 Bird LX 4.6 ---------------------------------------------------------------------------- Life's journey is not to arrive at the grave safely, in a well preserved body. But rather to skid in sideways, champagne in one hand and strawberries in the other, body thoroughly used up, totally worn out, shouting "HOLY CRAP! WHAT A RIDE" |
#111 | |
TCCoA Member
Car: 1991 Thunderbird Sport
Engine: 5.0 HO
1991 Ford Thunderbird Sport 1998 Ford F150 XLT |
#112 |
Ok, took the advice here and checked my subframe bolts. I set my torque wrench to 100 lb/ft and was surprised how loose they were. The problem is that I still haven't reached torque yet and the bolts feel as though they are just before stripping. I checked the wrench on my lug nuts and it seems correct as it will click on them (used it when I installed my new wheels) but it just doesn't "feel" right when tightening the k member bolts. Is this normal? I would guess that I'm around 80-90 lb/ft but am afraid to go further. The bolts felt as though they were tightening fine at first, but then they just started to feel "mushy" (yeah-technical terminology) the more I tightened them.
White 1997 LX Sport 4.6 all stock except for the wheels & stereo (yes, it even still has the factory air silencer) |
#113 |
Engine: 4.6L V8
#114 |
Car: 94 T-Bird
Engine: 3.8L
i have a rattle on smooth roads. seems like it's from the rear (left side mostly, but also right). i was thinking maybe shock mount bolts, but this morning when i stopped at a store i heard it while the car wasnt moving. it doesnt effect steering but it's very annoying. i'm thinking my exhaust may be touching something or a loose baffle in the mufflers.
1994 Thunderbird - 1997 3.8l engine/trans - air silencer delete - k&n panel - JMOD - SCT chip - dirtyd0g converter |
#115 | |
TCCoA Member
Engine: 5.0 HO
Rayo...
#116 |
Car: 94 T-Bird
Engine: 3.8L
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
