TCCoA Forumsjournalist
Go Back   TCCoA Forums > Car Related > Engine - 5.0L & 5.8L
Register Arcade Gallery iTrader FAQ Members List Search Today's Posts Mark Forums Read
Old 10-25-2009, 09:19 PM   #1
black V8
Car: 1991 Thunderbird Sport
Engine: 5.0 litre V8
5.0 timing
I think my timing might be off. A couple of years ago I had my timing changed to 14BTDC. These days when I put my foot into it on the highway it sounds kind of like a diesel, also when I go up a long hill if I don't kick it down a gear it will seam to miss. I always run Sunoco 94, so does this sound like a timing issue.
Thanks Tom
black V8 is offline   Reply With Quote
Old 10-25-2009, 10:14 PM   #2
decipha
decipha's Avatar
Car: 92 Tbird
Engine: 6.7
Send a message via AIM to decipha
not usually, 4 degress is safe with 94 octane
probably the pcv screen thats clogged up, its on the back of the intake manifold beneath the cowl closer to the driver side but pretty much center in the back. Pull put the pcv valve and you'll need some tweezers or the like to remove the screen. I just removed mine and tossed it, that made me realize how nice my old 5.0 could idle, even though prior to that it idle'd as i thought beautifully
black 90 5spd sc - 10% & exhaust
red 90 5spd sc - 10% & exhaust
titanium 91 auto sc - 100% stock
black 94 5spd sc - heads
92 5spd 408 turbo
decipha is offline   Reply With Quote
Old 10-26-2009, 12:02 AM   #3
black V8
Thanks decipha,
I new I was having an issue with this screen but didn't realize it would cause those symptoms as well, I'm gonna pull that thing out and chuck it this weekend.
Tom
Old 10-26-2009, 02:15 PM   #4
joker77_2005
Car: 1994 XR7
Send a message via Yahoo to joker77_2005
dont chuck it,clean it and put it back in.that screen filters out any large particles that maybe in the lifter valley
kinda like running ur car without a airfilter
mike
1990 ford f150 5.0
1990 cougar xr-7 5spd 5.0
1989 mustang gt 10.68@126.97
1984 tbird 5.0 auto
joker77_2005 is offline   Reply With Quote
Old 10-26-2009, 02:27 PM   #5
MadMikeyL
Car: 8991 Cougars
Engine: 3.8SC, 393
MadMikeyL's Arcade Awards
Snake
Ms Pacman
mike
If there are large particles in the lifter valley, your engine is about to die anyway and the PCV system is the least of your worries. If you clean it and put it back, it can just get clogged up again. I would also just throw it away.
91 Cougar LS 393, ported holley systemax 2 heads, typhoon intake, 1 3/4 longtube headers, 70mm halfshafted throttle body, more cowbell, M5R2 trans, aluminum driveshaft, engine lowered and moved back 1".
89 XR7 3.8SC 5-speed, under restoration/modification.
98 Mark VIII LSC, T45 swap and 3.73s. Soon to come, C-heads.
"Your buddy Mike is INSANE" -ClintD's dad
MadMikeyL is offline   Reply With Quote
Old 10-27-2009, 01:04 PM   #6
joker77_2005
Car: 1994 XR7
wrong,the egr passages are under the intake ,and do cook the oil and turn it into sludge grit and gunk,and the pcv screen filters out those particles from entering the intake and causing hung/broken valves and also carbon buildup in the intake
do the right thing and clean it ,then put it back in
or just take that filter out and suffer down the road
i guesss ford didnt know what they were doing
1990 ford f150 5.0
1984 tbird 5.0 auto
Old 10-27-2009, 02:53 PM   #7
MadMikeyL
Car: 8991 Cougars
Engine: 3.8SC, 393
Snake
Ms Pacman
Well certainly nothing big enough to damage your valvetrain is going to make it through the PCV valve. At worst you could say that something could get in there and make you have to replace the PCV valve, but it won't damage the engine. Also, if you have sludge, you don't change your oil frequently enough. There should not be any sludge, grit, or gunk, anywhere in the oiling system. If there were sludge in the valley, it would cause one of 2 things, either it would drip down and clog up the oil pump pickup and you would lose oil pressure, or it would block the passages and oil would not be able to drain back to the pan, and you would lose oil pressure. Like I said, if there are any particles in the valley large enough to be filtered out by that screen, then your motor has other issues and a PCV valve is the least of your worries. Now as for the screen, I have seen many 5.0s with that screen gummed up causing the PCV system not to work properly, and I have seen many 5.0s with that screen removed that have never had any issue. I have never seen one motor where it sucked something up through the PCV valve and damaged the valvetrain. That simply does not happen.
Old 11-04-2009, 07:33 PM   #8
tomnh
tomnh's Avatar
Car: 1995 cougar
Originally Posted by black V8 View Post
Thanks decipha,
Tom
Please don't just throw it out. You will just be sucking oil into your your engine. Replace it instead. That screen acts as a filter and oil seperator.
tomnh
in the boonies of New Hampshire
1990 Lincoln Mark VII. Full cobra mods.
1995 Mercury Cougar. Daily Driver, Stock.
tomnh is offline   Reply With Quote
Old 11-06-2009, 01:15 PM   #9
decipha
decipha's Avatar
Car: 92 Tbird
Engine: 6.7
its a screen not a filter, as stated it can do more harm than good
if it clogs and the pcv can't evacuate excessive crankcase pressure your rings will wear more and thus cause more engine wear than needed.
do your engine a favor and chunk it, its a bad design just like ford does with many things. I'm sure if it was that important they wouldn't have eliminated that screen in the 95+ 5.0 explorers and 351 equipped f series trucks
vB code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 1999-2007 Thunderbird and Cougar Club of America
Viewing and/or Posting to this forum constitutes full acceptance of our Terms Of Use.
