TCCoA Forumsjournalist
Go Back   TCCoA Forums > Club Related > Work in Progress
Register Arcade Gallery iTrader FAQ Members List Search Today's Posts Mark Forums Read
Old 07-09-2009, 11:21 PM   #151
v8_superbirdy
Clueless Poster
v8_superbirdy's Avatar
Car: 2006 gt premium
Engine: 4.6L sohc 3v
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
The PCM has no oil pressure input, the factory sender is only for the gauge.
wow thats lame seems like there should be an idiot light for something as crucial as that...i dont have a oil pressure gauge though as im 97 so i put one in have to say its a very nice feeling be able to see my actual oil pressure.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline   Reply With Quote
Old 09-26-2009, 11:14 PM   #152
carcrz
carcrz's Avatar
Car: 1989 THUNDERBIRD
Engine: 3.8 V6
good job dude
carcrz is offline   Reply With Quote
Old 10-11-2009, 06:21 PM   #153
NetKeym
TCCoA Member
Car: 1995 Thunderbird
Engine: 4.6L
Cool Gotta share this...
After reading all this thread about the "fake gauge", I have to share this story with you all. First off, I had no idea they even made fake gauges, now I know different and I thank you all. I WILL be changing my sender and modding my dash in the very near future on my '95 LX. Now, the interesting story.
I came across my T-Bird about 2 years ago. When I test drove it, I thought "wow, this car is pretty powerful". I had owned a '97 about 5 years ago that had nowhere near the pep this car has. This car will spin the tires from a dead stop! Anyhow, the seller told me he was selling it cause his "mechanic friend" told him that the oil pressure was getting low and it was going to have a "massive engine failure" in the near future. Well, I have noticed (while I've been driving the car around for 2 years...lol) that the gauge does read real low sometimes, but most of the time, it stays about half way.
After reading this thread, I realize it's probably a connection or the resistor failing. Thanks again all, and I hope you found the story as entertaining as I did!
NetKeym is online now   Reply With Quote
Old 10-11-2009, 10:26 PM   #154
rbrown
WooHooo
rbrown's Avatar
Car: 95 95 95 89 95
Engine: 1x4.6 4x3.8 lol
Since it's a 95 it's probably 3-4 quarts low from burning oil.
Just kidding. Sorta. Check your oil.
rbrown is offline   Reply With Quote
Old 10-22-2009, 01:11 AM   #155
CrystalPistol
CrystalPistol's Avatar
Car: 92 Sport & 95 LX
Engine: 5.0 & 4.6
Exclamation
Very possible.
A fine pair ... ... and whatever you do, Have a Safe Trip!
CrystalPistol is offline   Reply With Quote
Old 10-22-2009, 09:42 AM   #156
rbrown
WooHooo
rbrown's Avatar
Car: 95 95 95 89 95
Originally Posted by CrystalPistol View Post
Very possible.
I know mine was 3 low again the other day. I don't know how it still runs.
Old 10-29-2009, 09:42 PM   #157
tbirdguy
Car: 91 Tbird LX
Engine: 3.8L
would you believe after new valve seals it loses about 1/4 qt of 5w20 in almost 3000 miles?
91 3.8L LX
95 4.6L LX 40th Ann.
tbirdguy is offline   Reply With Quote
Old 10-29-2009, 11:29 PM   #158
rbrown
WooHooo
rbrown's Avatar
Car: 95 95 95 89 95
Just seals huh.... hmmmm.
Rodney
Old 11-01-2009, 09:24 AM   #159
NetKeym
TCCoA Member
Engine: 4.6L
Check Your Oil!
Yes, the car uses oil, but I keep an eye on that...lol I found the reason the gauge was flaky when I took the dash apart. I took it apart cause the bulb went out by the oil pressure gauge. Well, the bulb was good, just a connection had deteriorated on the ground for the gauge AND the light. Cleaned that up, now the idiot gauge stays right in the middle and the light works.
Now I bought the correct pressure gauge (I got a BWD S334 like tbirdguy) from o'reilleys and I have to take the dash apart again *sigh*. BTW, that 20 year old plastic is VERY brittle on my 95 so it sucks to disturb anything!
From what I understand from you all, the valve guides are shorter on the 1995 4.6 T-Bird heads and wear out quickly causing the valve seal leakage problems and subsequent oil consumption. I just keep feeding it oil. That Motor Honey engine treatment really helps. I used to have to add oil once every couple weeks, now I can go almost 2 months.
Old 11-15-2009, 05:06 PM   #160
geoph1986
Car: 1994 Explorer
Engine: 4.0L
How would this work with a digital cluster on an '89 Cougar LS? Is the resistor by the oil sender or is it part of the cluster circuit board?
geoph1986 is offline   Reply With Quote
Old 11-17-2009, 09:42 AM   #161
tbirdguy
Car: 91 Tbird LX
Engine: 3.8L
Probably not(but I'm guessing). The 20 ohm resistor just acts to position the pointer (which is a voltmeter or ammeter) into the normal range on mechanical gauge.
There are two possibilities(and tips to experiment):
1)If there is a true analog to digital converter in the cluster(like the temp gauge), you can connect a variable resistor with say 0 -100+ ohms and see if the bars change. This experiment will determine if there is an analog to dig converter. Or just buy the oil sender and see if it works. You may have to place another resistor in series or parallel to get it to work thru the range (like biasing).
2)If it is just wired to light up 1/2 the bars if the on/off switch registers oil pressure(eg 14 volts), then you have to do some engineering and get a hold of a VU-level meter type integrated circuit which can light up the segments as the voltage changes. I wanted to do something like that for the auto 4x4 on my explorer, as the coil energizes and locks the clutch in the xfer case, I would have a bar graph showing engagement.
That assumes you can control each segment individually (there is no multiplexing on the display).
I believe these cars have the 20 ohm in the wiring harness by the oil sender, not sure about the digital ones though.
91 3.8L LX
Old 12-22-2009, 06:48 PM   #162
beamerboy46350
beamerboy46350's Avatar
Car: 1992 Cougar LS
Engine: 5.0
Send a message via Yahoo to beamerboy46350
Wow Great read cant wait to do it!!!
beamerboy46350 is offline   Reply With Quote
Old 01-04-2010, 12:22 PM   #163
The_coop_08
The_coop_08's Avatar
Car: 1996 Thunderbird LX
Engine: 4.6 SOHC
Send a message via AIM to The_coop_08
Props for a fantastic mod!!! Now i can see how good my oil pressure really is with the new motor.
Silver 1996 T-bird
Mods: Clear corners, true dual exhaust with V-force mufflers and stainless steel resonator tips, Jmod, 180 degree T-stat, 22C plugs, and 93 octane tune by Lonnie Doll.
Waiting on installation: Mark VIII driveshaft with Spicer u-joints, Hayden 679 trans cooler, Built Dirty Dog 2800 Stall Converter, rebuilt aluminum pump with 3:73 gears
The_coop_08 is offline   Reply With Quote
Old 01-13-2010, 07:16 AM   #164
thunderhawk97
thunderhawk97's Avatar
Car: 1997 thunderbird lx
allright then,i have a wierd question then...after reading all this...my guage seems to a bit far from the norm..my 96 lx 4.6 oil guage works quite the opposite..it works like an oil guage should...up and down with the speed of th engine..so im confused now..did i miss something?
thunderhawk97 is offline   Reply With Quote
Old 01-13-2010, 10:46 AM   #165
Melon
13's or Mildly Broken
Melon's Avatar
Car: 1994 LX
Engine: 281
Send a message via AIM to Melon Send a message via MSN to Melon
If it moves (and you haven't modified the gauge yet), either by some odd chance it's already been done OR your oil pressure unit is going bad or the wiring is slightly loose. I'd bet money on the wiring or the sending unit.
-Melon
1990 Thunderbird Super Coupe 35th Anniversary 5spd - All stock and loving it
1994 Thunderbird LX 4.6L DOHC - Not Stock
1994 Thunderbird Super Coupe - Mostly Stock
1991 Thunderbird LX - Rust in Peace, my friend
Melon is offline   Reply With Quote
Old 05-26-2010, 11:30 AM   #166
Al_Florida
Whining Intakes Rock
Al_Florida's Avatar
Car: 04.5 S40 T5
Engine: 2.4l Turbo
^ What he said because your car has a dummy gauge.
_/_/_/_/_/_/_/_/ I like intakes that whine \_\_\_\_\_\_\_\_
# SELECT * FROM users WHERE clue > 0;
# 0 rows returned
# drop table users;_
Al_Florida is offline   Reply With Quote
Old 06-01-2010, 05:18 AM   #167
LoadedButane
Car: 1995 Cougar XR7
Engine: 4.6L
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
I just did this mod yesterday and it was easy as pie. $10 for being able to actually gauge the oil pressure rocks.
Geoff
1995 Mercury Cougar 4.6L stock and slow
LoadedButane is offline   Reply With Quote
Old 07-29-2010, 12:00 PM   #168
theterminator93
Car: 1997 T-bird LX, '94 XR7
Engine: 4.6L SOHC V8, 3.8L
Anyone have any luck finding a way to get the sender to fit on the 3.8s?
94 Royal Blue Cougar XR7 winter daily driver: 115k, bone stock!
97 Laser Red Thunderbird LX born 8-2-96: 124k on 8/19/10
Exterior:
35W 6000K HID Projectors
55W Halogen Fogs
17x9 Cobra Rs & Firehawk Wide Oval 255s
PBR Brake Upgrade
Interior:
150 MPH speedometer
Kenwood KDC-MP345U
Boston S-85s
JVC KS-AX3002 350W powering Panasonic sub
Powertrain:
PI intake
PI cams
J-mod
80mm 04 GT MAF
180° thermostat
B&M 24000 GVW tranny cooler
K&N conical filter/CAI
Waiting to be installed:
'93 Mark VIII drive shaft
POR-15 for the underbody
Next up:
2.5" Mandrel Bent True Duals with
Dynomax Super Turbos
theterminator93 is online now   Reply With Quote
Old 07-29-2010, 01:03 PM   #169
rbrown
WooHooo
rbrown's Avatar
Car: 95 95 95 89 95
I did my SC the other day. No sure if the brackets are similar. I used an extension to mountthe sender to the factory extension. Puts the sender about an 1-1/2" further out and not bumping into anything.
Old 07-29-2010, 01:24 PM   #170
theterminator93
Cool, I thought I read somewhere that an extension or pair of elbows was used to clear the alt/PS pump bracket but I wasn't sure.
Here's a picture just in case (yes, I know the serp is toast, and uhh, I snapped the head of the old sender off too ):
Exterior:
55W Halogen Fogs
PBR Brake Upgrade
Interior:
150 MPH speedometer
Kenwood KDC-MP345U
Boston S-85s
Powertrain:
PI intake
PI cams
J-mod
80mm 04 GT MAF
180° thermostat
Next up:
Old 07-30-2010, 01:36 PM   #171
theterminator93
Okay, managed to get it thrown together this afternoon. Here's what I ended up doing for you guys with the 3.8s:
I ran up to Home Depot for a few fittings this morning to try and build some kind of extension that made some sense. What I ended up using was a 1/4" x 2" brass nipple (Watts P/N A-742) threaded into the extension coming out of the block into a 1/4" coupling (P/N A-732). That threaded into a 1/4" MIPx 1/4" FIP 90 degree street elbow (P/N A-739) pointed towards the bottom right, then into the sending unit. I did have to extend the lead a couple inches, but it works just fine. I had to thread the extension and elbow into the coupling before screwing it into the extension on the engine. It was a tight fit getting it in tightly and at the right angles, but it worked out well enough.
The sender I used was the S334 from Advance Auto. I placed my order online and selected in-store pickup and used the P20 code for 20% off, so I got the sender for $8.31. For the three fittings I spent $8.42, so in total this set me back only $16.73. Here are a couple pics:
Exterior:
55W Halogen Fogs
PBR Brake Upgrade
Interior:
150 MPH speedometer
Kenwood KDC-MP345U
Boston S-85s
Powertrain:
PI intake
PI cams
J-mod
80mm 04 GT MAF
180° thermostat
Next up:
Old 08-23-2010, 11:10 PM   #172
Earl
Earl's Avatar
Car: 1996 FORD THUNDERBIRD
Engine: 4.6 V8 2/3 PI
Send a message via AIM to Earl
After many years of lusting over this cool mod, I Finally did it...used the factory motocraft sending unit...
I had to do some adjusting and wiggling to get the wiring to stretch far enough to fit...the wire it real tight, which i don't really like, but we'll see about fixing that up.
Soldered the jumper wire onto the cluster and the guage behaves like a real oil guage now
I did, however, dump the contents of the oil filter onto the driveway when I unscrewed the fake sending unit and I had to unscrew the real sending unit because I lost the wire above/under the sending unit the first time I scrwed it in, so, hopefully I didn't screw it up, as in, having to re-apply new teflon tape....we'll see.
So far so good...can't drive the car though since a tire decided to die tonight...
Used tires? Never Again!
Earl is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1999-2010 Thunderbird and Cougar Club of America
Viewing and/or Posting to this forum constitutes full acceptance of our Terms Of Use.
TCCoA is part of the Authority Auto Network. TCCoA's suggests the following webpages for your parts needs: Thunderbird Parts, Cougar Parts, Performance Parts, Car Parts, Wheels, Headers.
