TCCoA Forumsjournalist
Go Back   TCCoA Forums > Car Related > Engine - 5.0L & 5.8L
Register Arcade Gallery iTrader FAQ Members List Search Today's Posts Mark Forums Read
Old 12-26-2002, 02:55 PM   #1
krusher
Posts: n/a
Question Aod
got a problem with the AOD... its reving like crazy in Overdrive.... I can push down on it and it revs but only go up in speed slowly.
Old 12-26-2002, 02:58 PM   #2
dugweed
dugweed's Avatar
Car: 1993 THUNDERBIRD LX
Engine: RUNS
Send a message via AIM to dugweed Send a message via Yahoo to dugweed
check out the plastic grommet on TV cable. it is hooked up to the throttle linkage.
if it is broken, your trans is running too low of p[ressure and WILL BURN UP, if it hasn't already.
Mike
__________________
93 LX 5.0, WP WINDSOR JR's, E-303, GT-40, JBA's,2 1/2" DUALS, 70mm TB, 73mm C&L, MSD IGN., B&M HAMMER, LENTECH 10" CONV., STREET TERMINATOR V/B, CUSTOM STEEL DS 3.73:1 TRAC-LOC
14.550@94.45mph...246hp..294 tq
my cardomain site
1993 Harley-Davidson Electra Glide Sport
2001 F250 Super Duty supercab....diesel
dugweed is offline   Reply With Quote
Old 12-26-2002, 03:00 PM   #3
krusher
Posts: n/a
I'm thinking its already cooking... where's the cable at?
Old 12-26-2002, 03:05 PM   #4
dugweed
dugweed's Avatar
Engine: RUNS
it goes from the throttle body to the trans.
the grommet i am talkin about is on the throttle linkage. It is what connects the cable to the linkage.
it is a black plastic piece from factory, replacements are white or there is an updated brass bushing, and a clip design.
Mike
__________________
my cardomain site
Old 12-26-2002, 03:07 PM   #5
krusher
Posts: n/a
would this also cause the tranny to bring the engine tach up even without pressing the gas peddle (this made stopping a pain...)
Old 12-26-2002, 03:20 PM   #6
dugweed
dugweed's Avatar
Engine: RUNS
no it shouldn't affect idle speed, unless it is getting between linkage and holding it open.
here is a pic of tv cable and loction......your intake will not look like mine but it should be cl;ose enough for you to get idea of location
#1 is the cable itself
#2 is where the cable connects to throtle body.(grommet)
hope this helps....
btw, if you have driven it like this for a while, you probably have done damage to your trans.......they will not last for 50 miles with the cable off.
sorry bout the bad news .
good luck,
Mike
__________________
my cardomain site
Old 12-26-2002, 03:30 PM   #7
krusher
Posts: n/a
found problem... cable is just hanging there... just started happening today so I'm not worried... just wondering how to fix it right now at 4:26pm...
Old 12-26-2002, 03:43 PM   #8
dugweed
dugweed's Avatar
Engine: RUNS
all i can say is DON'T DRIVE IT!!
auto zone might sell the grommet, but again DON'T DRIVE YOUR CAR LIKE THAT IT WILL BURN UP TRANS!!!!!!!!!!
you might try callin local tranny shop, they usually have part in stock.
Mike
__________________
my cardomain site
Old 12-26-2002, 04:17 PM   #9
Mustang5L5
Mustang5L5's Avatar
Car: 1 Mustang-Mark VIII
Engine: 5.0-4.6 DOHC
Send a message via AIM to Mustang5L5
About 20,000 miles ago, i found my car revving like crazy in OD on the highway. There was no place to pull over so i continued on 50 miles to where i lived. I get home and find the cable hanging there. I get a new gromet from pep boys and use a cotter pin around the post to secure the cable. Works very well. Ford sells a metal replacement clip that will prevent it from ever popping off again
__________________
Mike
--'03 Mustang GT 5-spd--
--'88 Mustang LX 5.0L --
--'93 Lincoln Mark VIII--
The infamous Porno Mark 8
Mustang5L5 is offline   Reply With Quote
Old 12-27-2002, 10:08 AM   #10
krusher
Posts: n/a
I just fixed it with a hair tie and a S hook for picture frames... I'm all about riggin the car until I have the time to go and get the right part... it works fine right now for now... until I can get the new grommet. wonder how it popped in the first place......
Old 12-27-2002, 10:41 AM   #11
Blown306
Blown306's Avatar
Car: 1993 Thunderbird LX
Engine: KenneBell 306
Because the grommets dry out and get loose. The FIRST thing I did with my new trans was to replace that crap with the brass bushing and pin.
__________________
- Blown306 "Putting the THUNDER back in the BIRD"
Past President, Webmaster - Chicagoland Thunderbirds
'93 LX Kenne Bell 306
'01 Mustang GT Convertible
'02 Excursion Limited Ultimate Diesel
'03 Harley V-Rod - Two Tone Anniversary
Blown306 is offline   Reply With Quote
Old 12-30-2002, 05:28 PM   #12
krusher
Posts: n/a
well put a new ford replacement grommet in cost $1... good enough till I work up the engine. And also changed out the headlight switch since that damn thing went last night... if anyone's wondering... quick replacement and good investment... IT REALLY SUCKS when your driving down a road and all of a sudden your headlights go out.
vB code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1999-2010 Thunderbird and Cougar Club of America
Viewing and/or Posting to this forum constitutes full acceptance of our Terms Of Use.
