#1 |
Car: 96 Thunderbird
Engine: pi top end swapped
opinions about newfangled pulstar
has anyone heard of these things? http://www.pulstarplug.com/howtheywork.html
what does anyone think? looks awefully complicated for a spark plug
__________________
Shipping out to basic training for the army on april 12th! ![]() Bird is on serious down time
#2 |
JENIUS
Car: 1989 cougar
Engine: 5.0ooo Yeah (306)
I've seen this subject motioned here before, but I don't think anybody here has tried them yet.
$200.00 for eight plugs is a little steep.
__________________
I've come into this world with nothing and still manage to have some of it left. http://www.cardomain.com/ride/2902509/1 |
#3 |
Car: 96 Thunderbird
jEEzahs thats ridiculous
__________________
#4 |
TCCoA Member
Car: 1994 Cougar
Engine: 4.6SOHC
I don't like the odds of that bet for $200; I'd try it if it was about half that much.
__________________
Some people know the price of everything but the value of nothing.
#5 |
Refrigerator Raider Hater
TCCoA Member
Car: 96 LX
Engine: 281.3130969939CI
Junk. Chances are your engine will run worse.
__________________
Matt "Looks Like Egon" Davis 96 Alpine Green V8 02 Audi A8L 4.2Q in Black I buy my OEM Ford parts at 10% over dealer cost from Steve in White Bear Lake, MN. You drive "like a man possessed"... by a woman! |
#6 |
Car: 96 Thunderbird
thats was my theory. unless you got some kind of tune
__________________
#7 |
JENIUS
Car: 1989 cougar
If I was going to spend another $200.00 on my ignition system I would through in 8 autolite plug's and THIS MSD BOX.
__________________
#8 | |
TCCoA Member
Car: 1997 Mark VIII LSC
Engine: 4.6L DOHC
![]() And I usually shy away from places that say, "Tests at an independent laboratory"... give me a name or take a walk. ![]() Complete BS (IMHO). It looks like all they did was make COP into CIP (Coil in Plug). ![]()
__________________
97 Lincoln Mark VIII LSC (Chip'd, 3.73 T/L... so far... ) 97 Ford Aspire (Slow, but getting 36 mpg (f'n Ethenol!! )84 F250 Dually w/6.9L Diesel (7.3L IDI pending) 73 Mercury Cougar Convertible w/351C 4V (Partially Restored) 69 F100 LWB w/460 Engine 76 Glastron Carlson 23' Jet Boat w/460 CJ Engine |
#9 |
Moderator & Teksid Whore
Lifetime Member
exactly....only actual current-flow will heat up components.....just like a car audio amplifier.....disconnect a speaker, and then crank up the source signal....the voltage at the speaker output terminals will increase accordingly, but no power will be generated since no current is flowing...therefore the amp will not heat up anymore than what it normally does when it is idling
__________________
#10 |
Car: 96 Thunderbird
my amp had a wicked cam in it you shoulda heard its idle. it was mean.
__________________
#11 |
Time is the fire in which we burn..."
Lifetime Member
Car: 1996 Cougar XR-7
Engine: 4.6l
The plug does heat up a lot...
But only at the point the spark is hitting the electrode. Think TIG welder; the tungsten tips wear out in the same way; plasma erosion of the electrode.
The heat there is the big reason for both platinum and copper core plugs. The platinum resists the plasma from the 'Ballistic Electrons' being driven across the gap at 100kV+. The copper core makes sure the thin platinum plating doesn't get vaporized. Non plated plugs get replaced a lot in our cars. Ever notice the two plugs original to our cars? One has platinum plating on the ground electrode, one on the tip. Is F*rd cheap or what? ![]() These plugs are BS; adding another coil in series is going to stretch the spark out, but adding spark duration to our systems really isn't needed. It shouldn't hurt anything...but that plug also looks like it has pieces that make an additional gap in series, which our systems already have. (our other plug firing on the exhaust stroke.) If you have massive oil fouling, this would probably make it work until it breaks the rest of the way... The extra gap thing is how tasers work as well... ![]() IMHO our coils are pretty good... I've built some cool things from ones that were partially bad. Amazing what you can blow up with a 555 timer chip, a car battery, and one of these coils... The coils break at about 20W of power; that makes this wild looking purple plasma. (DTTAH!) The chevy ones are cool too, but break easier. ![]() If our coils won't light it, it can't be lit, AFAIK. They go bad, but I wouldn't run my hand down one of the wires to look for a leaky spot! (I bet they don't teach that trick in auto mech anymore...)
__________________
Red '96 Cougar XR-7 240k mi. '02 GM 4R70W PST DS : Empty, awaiting 03 PI engine and friends. Black '96 Cougar XR-7 (Lazarus) 160k mi Black '97 Tbird Limited Edition 95555k Bent, not broken. ![]() One man's Mystery is another man's Misery... No matter how good she looks; someone, somewhere, is tired of her sh*t. The truth is out there, its a big pile of green paper covered with dead presidents. |
#12 | |
Car: 96 Thunderbird
OK so my theory on these things seems to be a popular one. thanks for the opinions.
__________________
#13 | |
Lifetime Member
Engine: 4.6l
a coil running from a car battery will melt stainless! Look up a 'Jacobs Ladder' ; the GM coils have towers with exposed electrodes, and you can make a JL just by wrapping wire around the posts, and fanning it out to about 12" at the top... As you crank the frequency up, the spark will travel up the wires, until it runs out of power, and extinguishes...then it will start over from the bottom. I used stainless wire from a broken antenna...when I hit the coils sweet spot, it went all the way to the top, turns purple, about half an inch wide, and started melting the wire. (Did not extinguish!) It ran down the side of the wire, as I'm trying to shut it down... ![]() It blew the coil about then, but at least I know how far it will go... ![]() BTW, DTTAH is don't try this at home; I'm used to working with HV...
__________________
#14 |
Not Blinking Anymore
Anyone try these out yet? They seem interesting....Here's some test results I found http://sparkplugs.com/sparkplug411.a...Results&mfid=0
http://forums.corvetteforum.com/show....php?t=1827136 (read well into the thread)
__________________
2002 Chevrolet Impala http://members.tccoa.com/kewlbird/ |
#15 |
Lifetime Member
tests are skewed because on blown applications, smaller gaps are beneficial to producing power.....do that on an N/A car, and use proper gaps, and viola, behold the truth
__________________
#16 |
thread killer
Car: 94 THUNDERBIRD
Engine: 4.6L SOHC
i will tell my ricer freind about them and he will probably bye them
#17 | |
Lifetime Member
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
