I have way too much that I will never use so it's time for it to go. All money raised will go to a good cause..my engine swap fund.
If It's not on the list below, I don't have. All prices are obo and do not include shipping. Shipping available for purchases totling $20 and over. Local pickup only on large, heavy, or fragile items. I accept Paypal or postal money order for payment. Please be aware that I wait for the money order to clear the bank before I ship. Pictures are available on request,
94-97 Washer Fluid Reservoir - $10
CompCams Vacuum Canister Model 5200 Black (NEW) - $20
Passenger Power Mirror - $20
Driver Side Power Mirror (Qty. 2) - $20
Set of 4 Center Caps for XR7 16” Wheels (OK Condition) - SOLD
Rearview Mirror - $10
97 Gage Cluster (177k miles) - $40
97 Gage Cluster Lense - $10
Inside Door Handle (Passenger Side) - $10
Window Motors (Left and Right) - $20/Side
VSS - $10
Taurus LED 3rd Brake Light - SOLD
96-97 Fuel Rails - SOLD
02-04 Mustang GT Intake Tube - SOLD
96-97 Thermostat Housing - 10
96-97 IAC Tube - $5
94-97 Power Steering Reservoir - $10
96-97 Evap Vacuum Hose - $5
PI Intake with Aluminum Crossover - SOLD
PI Cams (NEW Romeo Takeouts) - SOLD
Aviator Throttle Body (70mm Upgrade for 2V) - $100
Premium Sound CD Player - SOLD
97 Premium Sound Amplifier - $20
Set of 4 Premium Sound Speakers - $20
Lincoln DOHC Coil Covers - $30
94-97 ATC Unit - SOLD
Set of 8 24lb Injectors (New Style) - $80
Set of 8 24lb Injectors (Old Style with Fat Body) - $60 SOLD
Set of 8 19lb Injectors (Old Style with Skinny Body) - $40
96-97 Thunder Bird Bra (Almost New, Bumper and Hood) - $80 SOLD
4.6 Coil Pack (Qty. 2) - SOLD
1 Set of Good Door Hinges (Upper and Lower) - $30
4.6 Underdrive Water Pump Pulley - $20
4.6 Harmonic Balancer - $10
4.6 Water Pump Pulley - $10
4.6 SOHC Alternator with Underdrive Pulley - $40
89-95 Latching Fuel Door (Door, Housing, and Actuator included; some fasteners missing) - $30
Manual Fuel Door - $10
Trunk Trim - $10
Thunderbird/Cougar Door Sills - $20
Mark VIII Door Sills - $30
Thunderbird Exterior A-pillar Trim (Right and Left Side of Windshield to Back Edge of Door) - $40/Pair
Thunderbird Exterior C-pillar Trim (Back Edge of Door to Right and Left Side of Back Window) - $40/Pair
Trim for Top of Windshield - SOLD
Trim for Rear Window (Upper and Lower, NEW) - SOLD
JL Rear Shock Tower Brace - SOLD
94-95 Gray Cougar Steering Wheel - $20
OEM Front Differential Bushings (40k) - $10
OEM Rear Differential Mount (60k) - $20
CCRM - $20 SOLD
Multifunction Switch (Near New) - $20 MIA
94-97 Thunder LX Driver's Airbag - $40
94-97 Cruise Control Switches (2 Pairs) - $10/Pair
96-97 OD Switch Wiring Harness - $10 SOLD
94-97 Headlight Switch (Qty. 2) - $10/each
94-97 Dimmer Switch with Autolights - $10
94-97 Dimmer Switch without Autolights - $10
Mark VIII Shifter with Chrome Button - $40 SOLD
Moog Steering Rack Bushings (NEW) - $15 SOLD
94-95 Gray Dome Light without Sunroof - $5
96-97 Coil Pack Brackets (Driver and Passenger) - $20/Pair
96-97 IAC - $10
96-97 EGR Sensor Bracket - $10
EGR Sensor - $10
Hood Release Bracket - $10
Lower Radiator Mounts - $10/Pair
96-97 Alternator Bracket - $20 SOLD
Header Panel Brackets - $20/Set of 5
Airbag Sensor Brackets (Right and Left) - $10/each
Fender Bracket to Core Support (Passenger Side) - $10
94-95 SC Rear Speaker Covers for Cloth Interior - $20
96-96 Thunderbird/ Cougar Lighted Sun Visors for Sunroof - $30
94-04 Mustang Goodrich Stainless Steel Front Brake Lines (NEW) - $50 SOLD
Thunderbird Third Brake Light Housing - $10
Thunderbird Third Brake Light Housing w/ T-Bird Logo - $15
Third Brake Light Replacement Harness - $10
Thunderbird Black Third Brake Light Cover - $5
Parking Brake Pedal - $20
94-97 Defroster Switch - $5
96-97 Hood Release - $10
Thunderbird Weather Stripping (Both Doors) - $40/Set
Trunk Release - $10
Front Airbag Sensors - $20/each
Heater Box Motor - $10
Sunroof Drain Tubes - $40/Set
Brake Pedal Pad - $5
Spare Tire Hold Dows (Qty. 2) - $5 1 SOLD
96-97 Thunderbird Rear Bumper - $20
Trunk Carpet - SOLD
Spare Tire Covers (Qty. 2) - SOLD
94-97 Wiper Motor Assembly - $40 SOLD
Walboro 190Lph Fuel Pump - $50 SOLD
94-97 Shifter Mechanism with Cable - SOLD
Fuel Filter Shield - $5
Evap Canister - $20
Evap Sensor - $10
97 AC Lines - $ 50
96-97 Thunderbird Body Trim (Driver Door Sold) - $10/Fender, $20/Quarter, $30/Door
Brake Proportioning Block 4-Wheel Disc Non-ABS - $30
Mustang Donut Spare - $20
97 Sunroof Assembly without Glass (38k) - SOLD
97 Cupholder Insert (Qty. 2) - $10/each 1 SOLD
91-92 Thunderbird Sport Trunk Emblem (Qty. 2) - $10/each SOLD
89-92 XR7 Emblems (Qty. 2) - $15/each
89-95 Thunderbird Trunk Light Badge - $5
96-97 Thunderbird Grill Emblems (NEW, Blue Feet Not Included, Qty. 10) - $10/each
Ford Hood Struts (NEW) - SOLD
Sport Springs (40k, No Rust) - SOLD
Set of 2 Rear Endlinks (40k, No Rust) - $20/Pair
Sport Rear Stabilizer Bar - $20
Drivers Door Glass - $30
Passenger Quarter Glass - $30
94-95 SC Automatic Console (Black Top and Tan Base Only) - SOLD
Mark VIII Oil Pick-up Tube - SOLD
89-95 Driver's fender (Ford replacement panel, used for 3 years) - $20
4.6 Radiator - SOLD
Factory Jack and Wrench - SOLD
Bryan
VSS - $10
96-97 IAC Tube - $5
Trunk Trim - $10
CCRM - $20 SOLD
96-97 IAC - $10
EGR Sensor - $10
Trunk Release - $10
Trunk Carpet - SOLD
Evap Canister - $20
Evap Sensor - $10
97 AC Lines - $ 50
4.6 Radiator - SOLD
Bryan
