Went to Circuit City and bought 2 pairs of these speakers today. They are incredible, a huge upgrade from the stock, non-JBL garbage. If you are looking for a better than average simple swap, consider these speakers while shopping. While they are not a good set of components, they do a good job of imitating them. Installation was a breeze, as I had all 4 installed in about an hour. Had to take a few minutes to figure out the door panels. Needless to say, I recommend these speakers to anyone looking to make a purchase.
I am going to use the Infinity components and coax's when I do the GTO's system next. THose will be amplified with an Infinity amp and I forsee a pair of Visonik 10" 500W RMS subs and a 1000W RMS 2 channel amp to drive them.
I have two of those in the 6x8 size in my door slots to use as my highs. I have Audiobahns of the same size in the back acting as subs (nothing getting sent to the tweeter).
I've got them in all 4 corners. I love them (although they're going bye-bye when I re-do the system). I'm a firm believer in the infinity's, a very good product.
if i'm not mistaken, one of the reasons the infinity's are so good, is that they have much better crossovers than a typical 2- or 3-way speaker.....a good crossover helps out a lot
good choice there, but me personally, i would stay away from that visonik stuff......also if the 1000WRMS amp is a 2-ch, then it is most likely not a class-D monoblock and will be a huge drain on your electrical system if it ends being a class-A/B amp and actually put out its rated power
X-overs are the stuff. I've got Kappa 5x7s, which blow the reference series outta the water btw, and they produce INCREDIBLE mids and highs. I absolutely love em. That and the fact they've got a rating of 100W RMA, 300 peak
well my pair of infinity reference 6x8 two ways sound about a thousand times cleaner than my pos pioneer three ways that are in the doors, the infinity ones have a really smooth high frequency response that almost sounds like my home stereo speakers, way, way, way better than stock, can't wait till i get some infinity components for the front.....
The Infiniti are nice, but after a/b'ing Infinty, MB Quart, and a speaker I'd never heard of(Arc Audio), the Arc's absolutely amazed me. I work in audio(both live and studio), so I get to listen to some nice systems, and was amazed by the quality and imaging of the Arc's.
It seems to me, and remember hearing is in the eye of the beholder, that Infinity has reached the same level as NoS- it's a name that eveyone wants, but not everyone needs. I strongly suggest listening without labels. You'll be surprised.
(please: no flaming My bird was broken into last Fri.)
They were $380 for the pair (6" components), so they are a little on the pricey side. But up against the MB Quart $1k speakers, they held their own, if not exceeding them, IMO. It's all about your own ears....
Since I'll have to unhook the tweeter for door panel removal(here's why), I'll get some install pics this time.
Damn, those are some expensive a$$ speakers I'm thinking I might do some small components sometime down the line and put em up on top of my dash, or do some serious custom work and put them IN the dash to makeup for the horribe placement of the door speakers from Ford
redneckcougarguy said:
you are a dork lol, i just want speakers that will last more than a year.
Can you hook up a low-power amp to the rear speaker wiring and have it work? Probably a stupid question, I know, but someone I work with mentioned that and I want to know if he's full of *@#$ or not.
Actually, the rears are wired to the rear power out on the head unit. The head unit has a setting that cuts power to the internal amps, and cleans up the pre-outs(just a bit). I just leave it that way.
You don't want to use adapters, I just cut off the harness then solder on some new connectors. Most good pairs of speakers come with the connectors, so you just need to solder two wires.
Honestly though I would buy some nice mdf adapters and put 6.5'' round speakers or 5.25'' round speakers in the stock locations, they sound much better than the 5x7/6x8.
I'm running two pairs of soundstream spl coaxials 5.25'' with mdf adapters in stock locations in my truck and i'm real happy with them.
PS- you are going to want at least a four channel amp, if you go with pretty much any aftermarket speaker. My tbird has the aftermarket headunit with aftermarket speakers and no amp and it sounds pretty crummy.
You can also use the stock 5x7 mount piece as a template on 1/2 MDF and make a baffle for it. It also helps stiffen the area where the (stock) hole is. There is also enough room for most external crossovers above the speaker, and in front of the door controls.
As my bird is getting repaired after it's break-in damage, I can't get any pics right now...
i had infinity reference awhile ago and moved to cerwin vegas... i love them!
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
