TCCoA Forumsjournalist
Go Back   TCCoA Forums > Car Related > Engine - 5.0L & 5.8L
Register Arcade Gallery iTrader FAQ Members List Search Today's Posts Mark Forums Read
Old 01-16-2006, 02:45 PM   #1
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
Pic request - 92+ 5.0 upper intake - TB & TV bracketry
Hello,
I'm wondering if it would be possible for someone to post (take?) some pictures of the throttle body and throttle valve (aod equipped) bracketry found on a 91-93 Cougar/T-bird with the 5.0 EFI engine. Close up pictures of the TB/TV cable are what I'm really after.
I'm performing a 5.0 EFI AOD swap on my 97 Ranger, and I'm using an SN95 Mustang intake. They were not equipped with the TV provisions, as the automatic SN95 Mustangs used an electronically controlled AOD-E.
Your intakes look like this correct?
http://i9.ebayimg.com/02/i/05/a9/67/66_1.JPG
http://i2.ebayimg.com/01/i/05/bc/1a/fa_1.JPG
Thank you for your help!
Kevin
Kevin K is offline   Reply With Quote
Old 01-16-2006, 03:45 PM   #2
MaddMartigan
It's all wrong.
MaddMartigan's Avatar
Car: 1993 Thunderbird LX
Engine: 342 Stroker NA
Originally Posted by Kevin K
Hello,
Kevin
Here is the best I can do. I took this before I pulled my entire setup. This is the stock picture because I want you to see it from the factory.
__________________
"When the only tool you have is a hammer, suddenly everything looks like a nail."
"Nothing is foolproof because fools are so ingenious."
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-Low Tension Oil Rings, Zero Gap Seconds
-10.5:1 Compression Ratio
Trick Flow Twisted Wedge heads
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
AEM Plug N Play EMS
Innovate LC-1 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline   Reply With Quote
Old 01-16-2006, 08:32 PM   #3
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
That is perfect. Thanks very much, that helps quite a bit.
If anyone else has any close pictures, I'd like to see them as well.
Great site!
Kevin
Old 01-22-2006, 03:40 PM   #4
Matt92LX
Car: 92 Thunderbird LX
Engine: 3.8, and 347
pics
Im going to be under the hood later on. do you need some closer pics? If you need pics of anything else, let me know now so I can get pics of those too..
Matt92LX is offline   Reply With Quote
Old 01-22-2006, 06:15 PM   #5
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
If you'd like to take some pics of the TB/TV cable bracketry, that would be great.
(If it's not too late already!)
Thanks for your help.
Kevin
Old 01-22-2006, 06:54 PM   #6
Matt92LX
its not too late, im going down to work on it this evening.. Im waiting for all the neighbors in my building (mostly older people) to be in for the night beofre I take another stab at my car.. Ill post them up later tonight, or tomorrow morning..
Old 01-22-2006, 08:29 PM   #7
jk69cat
resident old car guy!
jk69cat's Avatar
Car: 6469 galaxie/cougar
Engine: 347stroker/352fe
geez, i forgot how they looked stock
__________________
64 ford galaxie -FE powered beast!- currenty getting paint work done!
69 cougar standard- 347/c6 -efi restomod project-soon to be in paint prep
96 f150 supercab lifted beast!-currently undergoing much needed tlc, now running a performer efi intake
87 shasta roadmaster 29ft travel trailer- pimpdaddy camping!
mn12 less!
all american built and operated here!
jk69cat is offline   Reply With Quote
Old 01-23-2006, 10:25 AM   #8
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
Thanks Matt! I'd appreciate any pics you take.
I've got a line on a TB/TV bracket, hopefully I can get it for the right price.
Kevin
Old 01-23-2006, 11:39 AM   #9
jk69cat
jk69cat's Avatar
i know your using the stock upper and lower, but you may want to consider using a an explorer upper and lower, the throttle and cruise cables will be a more direct fit to your ranger.
__________________
mn12 less!
Old 01-23-2006, 01:07 PM   #10
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
Consider it considered.
I'll stick with what I've got thanks.
Old 01-24-2006, 08:34 AM   #11
Matt92LX
Im going to put the pics up later today.. the other night I had a little mishap while taking some photos, and now my camera dongle doesnt want to plug into the camera plug so Im going to be resorting to flash memory. I have a bunch of pics for work I have to get off that thing as well.. oh well. Ive got plenty of pics though, so it should be worth the delay.. didnt forget about ya.
Old 01-24-2006, 08:40 AM   #12
Matt92LX
I wish I had that problem myself.
Old 01-24-2006, 08:45 AM   #13
MaddMartigan
It's all wrong.
Well, it doesn't look like that anymore.
__________________
FRPP 42# injectors
3.73 gears
AEM Plug N Play EMS
Innovate LC-1 WB O2
OMGHI2U
Old 01-24-2006, 10:31 AM   #14
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
Thank you!
Old 01-24-2006, 10:41 AM   #15
tbirdbrain
Braincoating! It's what all the cool kids have!
tbirdbrain's Avatar
Car: 1993 bundle of joy!
Engine: 331ci of Happiness
[start threadjack]
DONT FEAR COLORS!
[/end threadjack]
__________________
www.BRAINCOATING.com..... Powder & Ceramic Coating
WWW.PRESTONSBOOKS.BIZ..... Books at really great prices!
tbirdbrain is offline   Reply With Quote
Old 01-25-2006, 11:58 PM   #16
Matt92LX
Better late than never ;)
here they are.. I was in the process of installing a bunch of replacement parts at the time of the pics being taken.. I also was installing a new throttle body linkage bushing. it fits into the throttle arm, and the TV cable clicks into it.. those things are notorious for going at the WRONG time!! I was behind an LAPD police cruiser waiting at a red light when it happened.. needless to say it was very scary stuff.. I pulled the car over and I taped the TV cable to the throttle arm with masking tape, and YAY!! I had my overdrive back!! It would shift into OD before, but would slip when you hit the gas.. I thought the tranny was trashed, and I overlooked the TV cable. it would be good practice to change all the bushings in the throttle body arm for that motor you want to put into your Ranger..
I had a buddy who use to live down the street from me with a Ranger that had a 5.0 swap.. the donor was his mustang that got screwed in an accident, but the mustang had a fresh 345 hp GT40 crate motor.. jeeze, that little Ranger was like a bat outta hell that way that took off, as long as you had traction! effortless tire spinning. Im quite sure that even a stock 5.0 will be pretty fast though too in that little truck; probably a lot quicker than our Birds in that case.
Image hosting by Photobucket
Heres the culprit.. Too bad that Ford used a crappy design for this throttle body linkage setup!
hope that helps!!
Old 01-26-2006, 08:52 AM   #17
Kevin K
Car: 97 Ford Ranger
Engine: EFI 5.0
Fantastic! Those are exactly what I was looking for! Thanks very much Matt!
I'll be sure to post pics once I've got the engine installed for the last time.
Kevin
vB code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1999-2010 Thunderbird and Cougar Club of America
Viewing and/or Posting to this forum constitutes full acceptance of our Terms Of Use.
