no good after head gaskets - TCCoA Forums
post #1 of 14 (permalink) Old 08-24-2007, 02:10 PM Thread Starter
89tird's Avatar
hey guys i got a 93sc, i bought the car running but wasnt running to good they hgs were blown, now after i did the hg's the car wouldnt start , i found out that the small wire on the starter might have gotten crushed by the engine when i did the engine mounts , so jumped it and car cranks through the switch , but no fuel since my injectors dont get power.
so im thinking the wire that goes from the ecm to the injectors might be crushed too, well i sprayed some fuel in the throttle body and car started and stayed running but sounds like crap , notice the down pipes still disconnected, i get like 10hg of vacuum and a loud squeel any advice ?? thanks http://s133.photobucket.com/albums/q...ent=choppy.flv
89tird is offline
post #2 of 14 (permalink) Old 08-24-2007, 02:39 PM
jtsmith's Avatar
Do you see oil pressure rise?
[urlhttp://www.explorerforum.com/forums/index.php?threads/bettys-i-want-to-be-a-mule-progress-log-thread.329322/]My Ride[/url]
Others linked in signature there.
jtsmith is offline
post #3 of 14 (permalink) Old 08-24-2007, 03:28 PM Thread Starter
89tird's Avatar
gauge doesnt work
89tird is offline
post #4 of 14 (permalink) Old 08-24-2007, 03:31 PM
jtsmith's Avatar
Originally Posted by 89tird View Post
gauge doesnt work
Gauge, or oil pump?
jtsmith is offline
post #5 of 14 (permalink) Old 08-24-2007, 03:38 PM Thread Starter
89tird's Avatar
lol sorry i was thinking of oil temp gauge , i havent tested for oil press how do i do that ?
89tird is offline
post #6 of 14 (permalink) Old 08-24-2007, 04:07 PM Thread Starter
89tird's Avatar
sorry like i said my oil press gauge doesnt work so how would i check the pressure ???
89tird is offline
post #7 of 14 (permalink) Old 08-24-2007, 04:09 PM
jtsmith's Avatar
You will need an oil pressure gauge. A real one, not the high- low thingy in a factory car. You need one which reads PSI
jtsmith is offline
post #8 of 14 (permalink) Old 08-24-2007, 04:20 PM Thread Starter
89tird's Avatar
dont tbirds have a low oil pressure light ?? i dont get any lights other than the check gauge light and the check engine , but still i cant check for codes
89tird is offline
post #9 of 14 (permalink) Old 08-24-2007, 04:23 PM
jco1385's Avatar
i have an oil press guage. sig check
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #10 of 14 (permalink) Old 08-24-2007, 04:37 PM Thread Starter
89tird's Avatar
looking at a video from a couple of days ago when it started oil pressure did rise , i just never thought about looking at the gauge didnt look today , thanks for offering the gauge , any more ideas ?
89tird is offline
post #11 of 14 (permalink) Old 08-24-2007, 07:10 PM
decipha's Avatar
sounds like somethings hitting something, i'd bet something isin't lined or something is bent, possibly a cracked head
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #12 of 14 (permalink) Old 08-25-2007, 10:47 AM Thread Starter
89tird's Avatar
car has remanufactured heads and they got pressure tested before i put them back on
89tird is offline
post #13 of 14 (permalink) Old 08-25-2007, 11:36 AM
sounds like a major vac leak is your ingintion switch ok if its bad it wont start is neutral safty switch connected at trans or shifter 5 spds have a clutch switch are oxy sensors hooked up?
mannysc is offline
post #14 of 14 (permalink) Old 08-25-2007, 11:53 AM Thread Starter
89tird's Avatar
yes thats what im thinking too vac leak , i see about 10hg or less , ignition switch is new , neutral safety switch is connected, oxygen sensors are connected but not threaded in the cats since my down pipes still not connected
89tird is offline
