Boost - TCCoA Forums
post #1 of 22 (permalink) Old 01-29-2008, 07:20 PM Thread Starter
Essex8800's Avatar
Send a message via AIM to Essex8800
Boost
Is there any reason my boost gauge would just stop reading?.......I worked fine when I got it....
1990 35th Anniversary Edition
My new project
Essex8800 is offline
post #2 of 22 (permalink) Old 01-29-2008, 09:55 PM
Gonzo's Avatar
The hose probably popped off the back off the guage. You need to pull the guage cluster and make sure it's still connected.
Steve
1993 LX converted to a 5.0/5 speed - Mac long tubes - SCT Pro Racer tuned by Lonnie and me - best E.T. 14.88 - mph 94.59
1991 SC - Stock..........Mostly
Gonzo is offline
post #3 of 22 (permalink) Old 01-30-2008, 11:23 AM
check vac ?boost line at back of retrun plenum near brakes it may have fell off or the usual it broke somewhere near or behind brake unit
mannysc is offline
post #4 of 22 (permalink) Old 01-30-2008, 03:41 PM Thread Starter
Essex8800's Avatar
Now im really concerned.....my car will not idle very long it dies......when i come to a stop sign it dies before i can put it in first!!! HELP
My new project
post #5 of 22 (permalink) Old 01-30-2008, 04:24 PM
Gonzo's Avatar
Did you check the boost line in the 2 places that were recommended? That would cause the problems you are explaining.
Steve
Gonzo is offline
post #6 of 22 (permalink) Old 01-30-2008, 07:13 PM Thread Starter
Essex8800's Avatar
that would cause the no read on the gauge and the stall?
My new project
post #7 of 22 (permalink) Old 01-30-2008, 07:29 PM Thread Starter
Essex8800's Avatar
lol even quicker q.........does the upshift light actually work?
Mine never lights up when driving only when starting
My new project
post #8 of 22 (permalink) Old 01-30-2008, 09:46 PM
Gonzo's Avatar
Yes it would, the guage has no reference and it causes a vacuum leak when disconnected.
Gonzo is offline
post #9 of 22 (permalink) Old 01-30-2008, 10:21 PM
rbrown's Avatar
Like he said.
And there is a shift light???
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #10 of 22 (permalink) Old 01-30-2008, 10:28 PM Thread Starter
Essex8800's Avatar
yeah it's an arrow pointing up in the tach....it lights when i turn the car on but not when i drive
My new project
post #11 of 22 (permalink) Old 02-01-2008, 12:36 PM
Old_coot's Avatar
Send a message via Yahoo to Old_coot
If you wind the engine up to high the shift light will come on.If memory serves me right mine comes on anytime I go over 5000rpms...............Dan
Old_coot is offline
post #12 of 22 (permalink) Old 02-01-2008, 04:09 PM Thread Starter
Essex8800's Avatar
lol I fixed the gauge.....anytime i got on it the damn hose pulled off of the supercharger....
My new project
post #13 of 22 (permalink) Old 02-01-2008, 04:22 PM
Gonzo's Avatar
Glad to hear you got it fixed
Steve
Gonzo is offline
post #14 of 22 (permalink) Old 02-02-2008, 03:29 AM Thread Starter
Essex8800's Avatar
lol this may sound stupid but I want my supercharger to be louder.... I read earlier that you can weld the sound ports shut to kill the whine......but I wanna go opposite with it
My new project
post #15 of 22 (permalink) Old 02-02-2008, 11:40 AM
David Neibert's Avatar
Closing the sound ports makes it louder, not quieter. Easiest way to get more supercharger whine is to change to a cold air intake that uses a steel or aluminum pipe.
David
David Neibert is offline
post #16 of 22 (permalink) Old 02-10-2008, 04:47 PM Thread Starter
Essex8800's Avatar
I need to ask another q....I hear a loud knock coming from my engine on hard acceleration, kinda sounds like my lifters but it doesnt do it at idle.....My dad said something about the throw out bearing but thought id ask on here too.....oh and does anyone know where i can find a set of bolts that holds the supercharger top on.....someone replaced mine and there is a leak around the top now.
My new project
post #17 of 22 (permalink) Old 02-10-2008, 04:54 PM
13's or Mildly Broken
If theres a vac leak around the blower top - pull it off and reseal it with Copper RTV or a good gasket if you can find one. New bolts may help, but won't totally cure the problem.
If you want to make the blower whine more noticeable, replace the stock rubber intake tube with an aluminum one. It will definiately be noticeable after that.
Loud knock could be a bearing maybe? I remember a knock when the bearing went out on my dad's 94 SC.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #18 of 22 (permalink) Old 04-04-2008, 07:18 PM Thread Starter
Essex8800's Avatar
I think my cat is rattling......man this car is bein a real pain...lol.....Would the cat cause my car to overheat or die if its clogged? cause its been doin that lately.....I've also noticed a huge reduction in power....but i cant afford to get all new cats!!! what to do???
My new project
post #19 of 22 (permalink) Old 04-05-2008, 07:51 PM
Yes the cats being plugged and breaking up will defanitely do that. My 4.6 did that too. I would check the prices on high flow cats. they are cheaper than you think. I took mine to a muffler shop, had 2 new cats and mufflers put on for just over $300
Robert M is offline
post #20 of 22 (permalink) Old 04-06-2008, 01:14 PM Thread Starter
Essex8800's Avatar
I checked fractory replacement and it was $500....
My new project
post #21 of 22 (permalink) Old 04-07-2008, 05:48 AM
Aftermarket will be less than half i bet
Robert M is offline
post #22 of 22 (permalink) Old 04-15-2008, 06:42 PM
Even cheaper if you get them on Ebay and just have someone cut the old ones out and put the new ones in. Don't trash on it with blown cats as you could blow the head gaskets.
The upshift light will come on at higher rpm in high gear. Mine comes on at about 160-180 km/h (100-120 mph).
Flex is offline
