Tail light issue - TCCoA Forums
post #1 of 11 (permalink) Old 05-16-2008, 01:46 AM Thread Starter
Send a message via AIM to Cougars4life07 Send a message via MSN to Cougars4life07
Tail light issue
My tail lights on my car don't seem to come on every time i hit the brakes. Anyone have any suggestions to fix it?
Cougars4life07 is offline
post #2 of 11 (permalink) Old 05-16-2008, 02:03 AM
have you checked the bulbs, conections, and do they have electric grease on them? a place to start. make sure they are greased my freind melted his tail light scoket because they had no grease
nwnsc is offline
post #3 of 11 (permalink) Old 05-16-2008, 12:20 PM Thread Starter
Ok, I'll look into those things. I just wasn't sure where to start.
post #4 of 11 (permalink) Old 05-16-2008, 12:25 PM
thunder chicken's Avatar
MFS issue.
97 'Bird w/an 04 Explorer lower, 8lb AED upper, Marauder TC, 93 MK VIII DS
thunder chicken is offline
post #5 of 11 (permalink) Old 05-16-2008, 02:34 PM
Originally Posted by thunder chicken View Post
MFS issue.
good point. if the problem is not back there i would go there next
nwnsc is offline
post #6 of 11 (permalink) Old 05-16-2008, 03:19 PM
carlosthekat's Avatar
Brake Light Switch around $10.00, its located underneath the dash board near the brake pedal. Here's a link with a picture...
http://info.rockauto.com/Airtex/Detail.html?1S5393.jpg
carlosthekat is offline
post #7 of 11 (permalink) Old 05-16-2008, 03:40 PM
when my mfs is acting up the turn signals, emergency flashers, brake lights and taillights all seem to quit. All I do, for now, is turn the emergency flashers on and off a few times and it all works again. I have another unit waiting in the wings tho to replace it when that fails to work.
post #8 of 11 (permalink) Old 05-16-2008, 04:40 PM
decipha's Avatar
i 2nd the brake light switch
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #9 of 11 (permalink) Old 05-18-2008, 10:40 PM Thread Starter
I don't know if this helps or not, but when i tap the brakes it does kick the cruise off.
post #10 of 11 (permalink) Old 05-19-2008, 12:39 AM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
That makes it sound even more like the brake light switch.
Your car doesn't think you are activating your brakes.
*Edit* My bad, I thought I read that the brakes didn't kick off the cruise.
n/m
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #11 of 11 (permalink) Old 05-19-2008, 11:26 AM
rednsilver94sc's Avatar
Send a message via AIM to rednsilver94sc
i second bad wiring
kicking out of cruise control the cars getting the signal from the switch so it knows you hit the brakes if the switch was bad the lights more then likely would stay on and not turn off,
rednsilver94sc is offline
