Vacuum leak - TCCoA Forums
post #1 of 7 (permalink) Old 06-06-2008, 09:45 AM Thread Starter
Vacuum leak
Pretty obvious hissing sound, coming from back of engine. After brief start and a high idle, it drops out and dies. Im not sure which line it is, but im sure they are all old and could use replacing. Could I go to parts store and just tell them I need vacuum lines, or 3/8 line or what do I ask for, Im not sure if there is a specific parts number on it. Also, will i need to replace the plastic t fittings? Maybe someone could just give me a basic run down. The haynes manual doesnt say too much about it.
SCarSC is offline
post #2 of 7 (permalink) Old 06-06-2008, 10:59 AM
Send a message via AIM to rzimmerl
There are no part number for the the various lines. You'll just have to purchase some various size hose to replace them, 1/4, 5/16, 3/8 are a couple sizes that I can think of right now. The plastic fittings should be OK, but they are cheap so if they are questionable replace them. A vacuum leak on an SC will drive you crazy.
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #3 of 7 (permalink) Old 06-07-2008, 09:09 PM
decipha's Avatar
you get get the t fittings in the help section at autozone
you'll have to remove the cowl to gain access to the lines back there
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #4 of 7 (permalink) Old 06-07-2008, 11:26 PM Thread Starter
Popped on a few new lines and finally realized that the PCV line had come off at the back, replaced that and all is cool now. Lines were cheap, one dollar a foot, not bad for a quick fix.
thanks
SCarSC is offline
post #5 of 7 (permalink) Old 06-23-2008, 07:05 PM
use goodyear fuel line .... works great when redoing boost hose's... i did it to mine and now no more hissing.. also check the intel plenum seal there a pain to seal sometimes what gasket maker are you useing??
Destructor90 is offline
post #6 of 7 (permalink) Old 06-26-2008, 10:20 PM
decipha's Avatar
this might sound wierd but i replaced my fpr vac line and my pcv line with a clear hard line from the local hardware store. That way I can see if my fuel pressure regulator goes bad and if it sucks oil through the pcv.
supercoupin'
decipha is offline
post #7 of 7 (permalink) Old 06-27-2008, 09:42 AM
Is that stuff oil and chemical resistant, if not it will melt, become gummy and collapse.
441 RWHP 435 RWTQ
rzimmerl is offline
