91 sc still hard to start - TCCoA Forums
post #1 of 5 (permalink) Old 07-12-2008, 11:24 PM Thread Starter
Red face 91 sc still hard to start
this car i got a new dis,crank sensor,cam sensor coil and it still hard to start like it jumped time but when it dose start it runs good im stumed please help thanks
donald turnage is offline
post #2 of 5 (permalink) Old 07-16-2008, 09:28 PM
decipha's Avatar
could be a fuel problem, have you checked the pressure at the rail?
how long has it been since the fuel filter been replaced?
perhaps since you changed all the ignition parts you should change the more common wear parts like wires and plugs.
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #3 of 5 (permalink) Old 07-27-2008, 05:39 PM
if u havent fixed the problem,change the ignition module
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #4 of 5 (permalink) Old 08-19-2008, 08:40 PM
change the coolant temp sensor did this on a 80 ford truck w/302 and cured the problem
ying is offline
post #5 of 5 (permalink) Old 08-20-2008, 09:32 PM
sc
check and change ur ing nition mod, check the presure at the fuel rail. 2 thinghs u have to check.....spark, fuel.
HFD-E2 is offline
