What would it take to get running again? Are the heads still any good? - TCCoA Forums
post #1 of 8 (permalink) Old 09-11-2008, 07:42 PM Thread Starter
Looking at a 93 SC/Auto with 122K miles on the car, that is very VERY clean and unmolested. I can get the car for $900-maybe less. However, it has a blown head gasket (imagine that ) The lady has spent money like fool on the car....$900 for motor mounts????
Anyways, the engine has about 4,000miles since the rebuild. Then the water pump developed a leak, and the lady owner took it to a corner shop who installed the pump (that she bought at Checker). The shop offered her no warranty because she bought her own water pump.
The very next day......it overheated within 10miles of driving and started blowing white smoke out the tailpipes. So she said she shut down, and hasn't restarted since being afraid of damaging the engine worse.
The other day I pulled dipstick and the oil is milky, and its been sitting like this for about 4 months now.
My question is....
Are the heads junk?
Is the whole engine junk (with 4K miles on it)?
What would it cost to fix it myself if the engine isn't junk? (head gaskets???)
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #2 of 8 (permalink) Old 09-11-2008, 08:52 PM
fly360's Avatar
Pull the heads and have a machine shop do a warp check and pressure check. As long as she did not overheat the engine too bad you should be about the $500.00 range with ARP head studs and you are doing the labor. Be safe and have a machine shop look at the heads just to be sure they are not cracked. Don't forget to take care of the foamed oil.
May the Gremlins never find you.
fly360 is offline
post #3 of 8 (permalink) Old 09-11-2008, 08:54 PM
fly360's Avatar
spinngwheels-sc and supercoupe performance should be able help you get close to the parts cost if the heads are still good
fly360 is offline
post #4 of 8 (permalink) Old 09-11-2008, 08:56 PM
fly360's Avatar
Also make sure the bottom end isn't making noise(rod knock)
fly360 is offline
post #5 of 8 (permalink) Old 09-11-2008, 09:27 PM Thread Starter
When I went to see it, the battery was dead from it sitting. I'm pretty sure by now, any water that could have been on the top of the pistons have drained, that it could be started up.
From the what the lady is saying, its really sounds like it could be nothing more than pulling the heads, checking them, new gaskets-plugs-02 sensors....and a ton of labor.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #6 of 8 (permalink) Old 09-11-2008, 10:33 PM
fly360's Avatar
I'm fixing to dive in the same deal, I'll let you know how it goes. If you decide to do it good luck.
fly360 is offline
post #7 of 8 (permalink) Old 09-12-2008, 11:28 AM
pirate_of_ms's Avatar
Don't forget that after replacing the head gasket, you still have to figure out why it overheated. Shady shop or not, the recent water pump change may not have been the problem, or by fixing one problem another showed up. It would blow to get all the sweat and money into it, just to have it happen again.
||Under a black flag we sail.||
pirate_of_ms is offline
post #8 of 8 (permalink) Old 09-13-2008, 03:56 PM
Plan on pulling the the entire engine. I have seen this all to often as the antifreeze will eat the bottom end. It will be fine in the begining if you change the oil out but soon after it will start knocken down the door of spun bearing time. If only they would have drained the oil out when it happend.
scbird is offline
