Fuel Pump runs with key off - TCCoA Forums
post #1 of 4 (permalink) Old 11-08-2008, 07:51 PM Thread Starter
My fuel pump runs constantly, even with the ignition off. If I don't disconnect the battery, it is dead in the morning. This is intermittant, but today was the second time this week.
I have been having alot of driveability issues and the CEL is on.
Faust is offline
post #2 of 4 (permalink) Old 11-09-2008, 10:57 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
maybe the ignition switch or a relay? i have the same problem in my caprice actually.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #3 of 4 (permalink) Old 11-22-2008, 11:09 AM
Check the fuel pump relay. It is mounted in the driverside trunk behind the wheel well.
I Love To Fix Cars is offline
post #4 of 4 (permalink) Old 11-22-2008, 12:38 PM Thread Starter
I should have posted, I replaced the relay in the trunk. Everything is fine now.
Faust is offline
