searched and no leads... please help - TCCoA Forums
post #1 of 57 (permalink) Old 03-14-2009, 02:04 AM Thread Starter
Hello fellas... ok, I have been on here and have looked up everything I can on this car. I swapped out motors from a doner 35 ann edition with 114k on it. the original motor spun a bearing or something, got the car free.... Okay, so... motor swapped, fresh oil, new fuel filter, new autolite 764's, new cables, and it still wants to run like a$$.... unplug the MAF, and it smoothens out for a bit, then runs rough, then dies. plug it in, it dies.... changed the MAF, still same. checked, and rechecked for the 5th time, no vac leaks. I used to own a 90 SC and I know what they are capable of... I just need to get this thing running right, then I can do all of the body and interior...
my main concern is that If it isn't running right, I have no need to focus on other stuff.... this is a 90 T-bird, SC, sealed up the IC tubes with copper permatex, and was going to but the teflon gasket set next week... maybe it will help, but any and all opinions are welcome. thanks in advance, Matt
hot90sc is offline
post #2 of 57 (permalink) Old 03-14-2009, 02:09 AM Thread Starter
also, I forgot to mention.... when she starts, I have engine shake, pretty good too... but @ about 2800 rpm, it smoothens out, my vac is running about 17-18in and boost gets to about 7-8 max... when WOT, I have a black watery substance coming from the tail pipes... cats???? it's not fuel, but smells kinda rich... tail smoke color is more of a whitish grey.... ??? thanks again...
hot90sc is offline
post #3 of 57 (permalink) Old 03-14-2009, 07:54 AM
thewishkah's Avatar
Send a message via AIM to thewishkah
is it possible this donor motor had bad head gaskets? check your oil see if you have any coolant in there, that would be the first step to look at with these engines. If you check that and it looks ok it could still be an issue(especially with the water and smoke you were explaining). See if you notice missing coolant. Start there and get back to us.
thewishkah is offline
post #4 of 57 (permalink) Old 03-14-2009, 09:36 AM Thread Starter
ok, will do... Man, I would hate to have to pull the entire top end apart, would probably just yank the motor, and rebuild it if I had to take it out again..... I'll let you know. thanks
hot90sc is offline
post #5 of 57 (permalink) Old 03-14-2009, 11:04 AM
Resident Line Creator
th3subtl3on3's Avatar
And if your not sure by checking the fluids you can do a compression test as well.
-Brian
th3subtl3on3 is offline
post #6 of 57 (permalink) Old 03-14-2009, 08:50 PM Thread Starter
got it! no water or coolant in oil, but it does smell a little gasy..... running rich? I am thinking change out the ecm... what are your thoughts? maybe with not very sealed ic tubes, it's telling the computer, "more fuel, more fuel" to make up for the extra air coming in? just a thought... maybe i'm totally in left field... plug in maf and it dies right off the bat... i'm soo lost. thanks for your input...
hot90sc is offline
post #7 of 57 (permalink) Old 03-15-2009, 01:09 PM Thread Starter
can I get a bump?????
hot90sc is offline
post #8 of 57 (permalink) Old 03-15-2009, 02:10 PM
thewishkah's Avatar
when you swapped out the maf was it for a new one or a used one? when my cars maf was shot as soon as I would plug it in it would die. Also pull your plugs, see if they are clean or damaged at all. did you see or hear this motor run before installing it?
post #9 of 57 (permalink) Old 03-15-2009, 02:22 PM Thread Starter
new plugs, used maf and I didn't see or hear it run, it was hit on pas side while driving.. wiped out rear rh quarter, and part of the pass side door.... i'll double check the plugs, and who knows, maybe I cracked one putting it in. never have before, but hey anything is worth a shot. thanks. I will pick up a new maf as well.. what about swapping computers... ne chance the programing might be different due to elevation? doner car was from az. and I'm in ut.
hot90sc is offline
post #10 of 57 (permalink) Old 03-15-2009, 04:32 PM
thewishkah's Avatar
I highly doubt elevation is the issue, however your ecm could have some type of issue, what ever parts you get check if they are returnable so if they don't cure the problem you aren't just throwing your money away.
post #11 of 57 (permalink) Old 03-15-2009, 10:48 PM Thread Starter
Thumbs up
good call... didn't even think about that... would have bought whatever and prob ended up with tons of parts i didn't need lol... more work on her tomorrow..
have any of you used car innertubes cut out to make up IC tubes at connections instead of buying teflon gaskets or that permetex crap? might try it myself...
hot90sc is offline
post #12 of 57 (permalink) Old 03-16-2009, 10:07 PM Thread Starter
ok fellas... I didn't get time to do anything on the car today, had to tear into a taurus... so tomorrow, I am going to swap out ecm, and if that don't change anything, I am going to try sealing up the IC tubes again, and if that don't work, I am going to do a compression test. what should be a good compression and about where should it be on the 3.8 sc'd engine's 1st stroke? and my other question, don't it usually bleed of a little or does it sit solid till I release the pressure in my gauge....... I haven't done many, but that's cause most time I haven't needed to do it....... thanks....
hot90sc is offline
post #13 of 57 (permalink) Old 03-17-2009, 11:42 AM
SplitPortBird's Avatar
if it runs like **** at idle I'd doubht it would be the tubes not sealing,,
A: do a compression check
B: ohm out those plug wires and make sure none are bad (ive had plenty of new wires that are bad outa the box)
C: what about a bad coil pack?
D: check the plugs for cracks in the procelian,, sometimes stockers drop em and then they are junk.
If it smooths out around 2800 then its sounds like its missing a cylinder possibly 2,, if no vacuum leaks then I would definately pull the plugs and look at em,,, maybe one is darker or wet or oil soaked and that would be the one to have the problems.
"" when doing the compression test you want someone to hold the throttle wide open (coil pack unplugged! and all 6 plugs removed) then crank it over letting the engine rotate about 3-4 times till you get the highest reading on the gauge.. record it and move onto the next cylinder.. obviously the max pressure is important but more important is that all the cylinders are within 5% of each other. if you come across a lower cylinder,, remove the gauge and retest it.. I'v had those gauges not seal sometimes causing a false reading.
SplitPortBird is offline
post #14 of 57 (permalink) Old 03-18-2009, 01:18 PM Thread Starter
compression test results.
First stroke Max psi
#1 100 135
#2 105 136
#3 100 132
#4 100 135
#5 105 138
#6 103 132
checked plugs.... all good, but they were all an even black color, not a brownish. but they are new too.... what ohms should the cables be at?
today I will change out the coil pack, and buy some new hose for all of my vacuum lines.. I really don't think there is a leak, but might as well, that way I know I can rule them out.
I will post up my results after cp and new vac lines. thanks for all the input...
hot90sc is offline
post #15 of 57 (permalink) Old 03-18-2009, 08:49 PM
compression test looks good.
alot of plug wires differ but 150 ohms per foot i believe is about the norm.
make sure the coolant sensor is good or perhaps install a new one,, it has alot of basis on what the rich/lean levels are at.. after warm up it starts to read the mass-air and 02 sensors
post #16 of 57 (permalink) Old 03-19-2009, 01:21 AM Thread Starter
Alrighty, here we go.... changed out coil pack... same... changed maf... same... plug it in and cover up most of the maf intake, and it idles really well. move my hand and it dies, sucking in too much air... would a bad IAC valve make it do this? I resealed the IC tubes... eh, same.... I just don't understand why when the maf is unplugged, it runs smooth for 2 min or so, then dies... I plug it in, smooth, then rough shaking and kaput... dies... I wanted to run a cold air intake, so I bought everything... and that's how I figured out if I hold my hand to the maf intake, plug it in, it runs real smooth... ???? I'm sooooo lost... I am here trying to figure it out... new pcv valve today too..... ne other sug???? sorry this is so long... I'm kinda venting.... but I really thank you all for your input! oh... I have a bad valve cover gasket leak on the LH side... right up front... would this have anything to do with my problems I'm experiencing?
hot90sc is offline
post #17 of 57 (permalink) Old 03-20-2009, 01:57 AM Thread Starter
bump please..... needing input badly.... don't want to give up.... what about changing out ecm, and/or complete throttle body???
hot90sc is offline
post #18 of 57 (permalink) Old 03-20-2009, 04:03 AM
The Band, not the Disease!
AnthraxBird's Avatar
i'd also check your Cam and Crank position sensors. Pretty cheap!
AnthraxBird is offline
post #19 of 57 (permalink) Old 03-20-2009, 06:56 PM Thread Starter
ok, so I changed out the temp sensors.. both... and I am going to change out the valve cover gasket. then I should have my teflon gaskets for the ic tubes.. I changed out the dis module. If this don't work, I will change out the ecm, havent done that yet... that is last resort lol.. even tho I have one. then it's on to brand new vacuum lines, and I mean ALL!!! I will post in a few days, and let everyone know the progress... thanks for all the help.....
hot90sc is offline
post #20 of 57 (permalink) Old 03-20-2009, 07:18 PM
If you put your hand completely covering the intake tube, and it still runs, then you definitely have a vacuum leak somewhere. Take a pair of plyers and crimp off one vacuum line at a time. When you get to the one that makes it run better when it is crimped, follow that line and see where it goes and where the leak is.
post #21 of 57 (permalink) Old 03-20-2009, 08:05 PM
Rayo's Avatar
check your plug wires..one at a time to make sure you have proper ohms..it's amazing how bad a car can run with bad plug wires..
1991 Ford Thunderbird Sport
Rayo is offline
post #22 of 57 (permalink) Old 03-21-2009, 02:04 AM Thread Starter
no, it dies when completely covered.. but, if I restrict air going in, it idles out nicely.....
never thought of the pinching off lines... will def try it.. I have to replace the valve cover gaskets so I will ohm out the plug cables.. I might try some different plugs too... thanks.. will post up in a few days..
also, I found a guy near me, maybe I can get him to park next to mine to verify all new vacuum lines going on are in correct order..
hot90sc is offline
post #23 of 57 (permalink) Old 03-21-2009, 10:03 PM Thread Starter
ok, so today I ripped off the whole top end of the motor and componets... top of heads look very clean!!! no sludge, no build up.... that is a good sign.. so I got the one valve cover gasket changed, but sadly it looked as if it was going to rain on me.. so if tomorrow pans out, I will change the other.... I also had time to replace EVERY SINGLE rubber vacuum hose, and they are all nice and tight on each end, but I hose clamped them any ways.. I also am going to a u-pull it wrecking yard tomorrow, and I am going to grab the mass airflow sensors just for fun.. I will ohm out plug cables, and I am changing plugs tomorrow... I will post up when I am all done, and let everyone know of my results... I am not going to order the teflon gaskets, I think the copper sealant is ok.... if you disagree, pls let me know, I will order them..
on that, my rubber innertube experience, well it failed... wanted to suck them in lol....
sooo...... till next time....
hot90sc is offline
post #24 of 57 (permalink) Old 03-21-2009, 10:04 PM Thread Starter
oh... have a question...
the lower ic tube... the bolt on spots.. where they bolt to the brackets, one on the ps pump, and the lower, while I have them out, can I wack them off with a cut off tool? will it make it easier to remove the lower tube if I ever need to again, with out removing the ps pump?
hot90sc is offline
post #25 of 57 (permalink) Old 03-22-2009, 03:08 PM
try swapping out the ignition module,i had the same problems as you plus was killing batteries and starters.i went threw the replace all sensors,seal and reseal the engine.finally i replaced the ignition module and all the problems went away
just a thought
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #26 of 57 (permalink) Old 03-22-2009, 04:05 PM Thread Starter
just a thought
mike
the grey dis module with two electric plugs, one on each side... I changed that.. same problems lol.. but thanks for the thought.. yea, I've tried just about everything..
I had a thought today, the original engine, was said to be bad.. said a knock... when I took off the blower and snout, I noticed the snout shaft and was bent.. don't ask me how they did it, but it's soo messed up.. maybe he engine is good, and the snout is what they heard go clunk, then grinding... i'm going to pull the pan and check it out... if I don't see anything wrong, I'll compression test it and maybe just clean her up and replace gaskets and what not, call her good.. what do you think?
hot90sc is offline
post #27 of 57 (permalink) Old 03-22-2009, 10:27 PM
That would be nice, but this really doesn't sound like a problem that is related to the bottom end, so you might swap the engines and find yourself with the exact same problem.
post #28 of 57 (permalink) Old 03-22-2009, 10:34 PM Thread Starter
would be nice.. and I agree... but with having another engine, I will have one to run, and one to take my time on and pump up.. cam, bore (just enough), heads, port and polish, have headers ready, blah blah blah... take my time.. do a nice mild upgrade and build... but if it hasn't thrown a rod, it just makes me that much happier... lol...
hot90sc is offline
post #29 of 57 (permalink) Old 03-23-2009, 12:00 AM
stupid question have you checked the harmonic balancer bolt, if not they have the tendency to break off the head from what i hear and still stay on, but cause a ton of problems, so maybe check that out, but that does sound like a vacuum leak to me, the worst parts are the intercooler bolts, had mine want to die after i pulled the tubes and i just tightened the lower one down really well and all is good.
SCarSC is offline
post #30 of 57 (permalink) Old 03-23-2009, 02:11 AM Thread Starter
No, that's not a stupid question at all... I never thought about it, but now that I do, when I put in the engine, I used the bolt to turn the crank to line up the torque converter... Good call though.. I had a bad HB on a 93 probe... drove fine then while driving, bam! just ran like crap... tried everything, then I noticed it when I had it on a lift lol... really good thought tho... and I will double check it tomorrow... come to think of it, the one on the probe, it was just the rubber that tore, and for some reason, even though the belts were turning, its like it wasn't in time... changed it out, and ran like a champ!
hot90sc is offline
