'94 EGR Code Trouble - TCCoA Forums
post #1 of 3 (permalink) Old 01-08-2010, 05:29 PM Thread Starter
Burnout Bob's Avatar
Send a message via AIM to Burnout Bob
I'm driving a 1994 Super Coupe with an automatic transmission, but there's a little problem. It's running an engine code reading "337-EGR Valve Position (EVP) sensor, Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT)- signal voltage too high"
I had done an engine swap over the summer and there was a pretty bad exhaust leak from the EGR pipe (from header to EGR disk thingy). Months ago, when the problem first came about, I replaced the EGR Pressure Transducer (that’s what AutoZone called it). The code remained.
This week I sent the car down to my mechanic friend Nick. I told him about the leak and the engine code, he agreed that fixing the leak should fix the code. Today I got the car back, no leak and it ran amazingly. After 30 minutes of driving, the Check Engine Light came on. Once I got home I scanned the codes and the same 337 code came up. The car did not seem to run any different. What should I look at next?
-Allan V
"I reject your reality and substitute my own."--Adam Savage.
Burnout Bob is offline
post #2 of 3 (permalink) Old 01-08-2010, 08:20 PM
Jeff Bratton's Avatar
Send a message via AIM to Jeff Bratton
Did you replace the tube? They will develop cracks/rust over time...sucking air into the tube. This will cause the CEL to come on. Also make sure the tubes nut where it connects to the manifold is tight too.
'89 Black SuperCoupe
Louisville, Ky.
260 RWHP / 349 RWTQ
Email me: [email protected]
Powered By Magnum Powers MPIII & other Bolt-On's
Check out My SuperCoupe
Jeff Bratton is offline
post #3 of 3 (permalink) Old 01-08-2010, 09:27 PM Thread Starter
thats what i thought, the pipe...its not leaking at all now. I will check the bolt on top but I'm sure that is tight. Thank you, I'll check that in the AM.
-Allan V
