What are the wiring pinouts of the ARC acuator pigtail? (Thunderbird SC) - TCCoA Forums
post #1 of 18 (permalink) Old 02-13-2010, 10:45 PM Thread Starter
Raptor22's Avatar
I am custom wiring to direct power the actuators to they work (manually of course) on my non-SC Thunderbird. Of course for that to work I need to know what pins do what on the pigtail.
Thanks.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 18 (permalink) Old 02-14-2010, 07:30 AM
bowez's Avatar
T/BK is Firm ride input
T/R is soft ride input.
They need to be a switched ground based on which mode you want to but it in, ie in Firm, the soft leads will be ground and in soft Firm leads will be ground.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 18 (permalink) Old 02-14-2010, 02:42 PM Thread Starter
Raptor22's Avatar
So what are the white and yellow wires for? How would I wire it to direct power the actuator?
Raptor22 is offline
post #4 of 18 (permalink) Old 02-14-2010, 03:07 PM
According to my 1991 electrical manual, Y/BK go to the steering sensor, and from there to hot-on-run (switched power). The various white ones (W, W/O, W/R, W/BK) go from the individual ones to the ARC controller.
I'd bet Y/BK goes to switched and the other two are exclusive to ground - but don't know for sure.
Have fun finding out!
RalphP is offline
post #5 of 18 (permalink) Old 02-14-2010, 03:22 PM Thread Starter
Raptor22's Avatar
Definitely man, I just want to find a to simply get the actuators to turn.
Raptor22 is offline
post #6 of 18 (permalink) Old 02-14-2010, 08:47 PM
bowez's Avatar
For your app you will only use the two wires I listed, all others are for sensor input/output.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #7 of 18 (permalink) Old 02-14-2010, 09:16 PM Thread Starter
Raptor22's Avatar
Awesome, alright thanks. There doesnt need to be any special resistance values does there?
Raptor22 is offline
post #8 of 18 (permalink) Old 02-14-2010, 09:25 PM
Where does it get the 12V to run it, then?
RalphP is offline
post #9 of 18 (permalink) Old 02-15-2010, 06:06 PM
bowez's Avatar
Raptor, not according to my EVTM
RalphP, depending upon the mode you want deteremines which is 12v and which ground.
Firm Ride: T/BK hot and T/R ground
Soft Ride: T/R hot and T/BK ground
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #10 of 18 (permalink) Old 02-15-2010, 08:17 PM Thread Starter
Raptor22's Avatar
So there is no negative, just +12v and ground? Its sounding like it works like a power window motor...
Raptor22 is offline
post #11 of 18 (permalink) Old 02-15-2010, 08:32 PM
bowez's Avatar
I stand corrected (looked at diagram a bit harder)
Y/BK is a constant ground
T/BK is Hot for Firm
T/R is Hot of Soft
All white wires or with white stripe is input wires and not needed for your app.
Sorry about miss reading diagram.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #12 of 18 (permalink) Old 02-15-2010, 08:39 PM Thread Starter
Raptor22's Avatar
T/R is Hot of Soft
So let me get this straight: Yellow is a constant ground, Black is hot for firm, red is hot for Soft?
Raptor22 is offline
post #13 of 18 (permalink) Old 02-15-2010, 09:01 PM
bowez's Avatar
Yes. sorry about misleading earlier
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #14 of 18 (permalink) Old 02-15-2010, 09:42 PM
Are we sure about all this???
This should be exactly like say the power windows, Locks and so forth..
The OE system uses two Switching relays, with them both resting to ground, then depending what is demanded, switching over to feed power to the correct lead to the actuator
Tan W/Black leads to the actuators would be switched to positive to move the actuators to the `FIRM' position
Tan w/Red Leads to the Actuators would be switched to positive to move the actuators to the `SOFT' Position
The other two leads Yellow w/Black and White or w/Black, Red, Or Orange is so the Module to know if the Actuators have Moved to the Soft position?? (Maybe it was firm)
91 XR7 is offline
post #15 of 18 (permalink) Old 02-16-2010, 09:40 AM Thread Starter
Raptor22's Avatar
Awesome, thanks. I needed to know so I can have my friend design a circuit to an upfitter switch in my cabin.
Raptor22 is offline
post #16 of 18 (permalink) Old 02-16-2010, 09:53 AM
Just remember to use a momentary switch when doing it, No need to be burning out the actuators
Heck you should be able to determine which position the switch in the Actuators are closed, and if in the `firm' position you may be able to use one to turn on the firm ride light
Well i just checked my Actuator, and the switch closes when in the `Soft' Position.. So it can still be done thou
91 XR7 is offline
post #17 of 18 (permalink) Old 02-16-2010, 10:17 AM
Originally Posted by GRNDPNDR View Post
Well, Since there is quite a bit of info here, and everything I've found has been spread out across multiple threads, I'll post some stuff here so it'll be in one place.
Here are the diagrams for the harness' as originally posted here
1996 Cluster 1
1996 Cluster 2
1997 Cluster 1
1997 Cluster 2
Cluster Re-pin Chart - Available as an excel file if anyone wants it.
post #18 of 18 (permalink) Old 02-16-2010, 06:07 PM
bowez's Avatar
Here is the schmatic
93 SC Tbird
93 5.0 Tbird
bowez is offline
