feeling the loss of power - TCCoA Forums
post #1 of 6 (permalink) Old 02-27-2010, 11:12 PM Thread Starter
I have a 93 sc, and when getting into the throttle (full throttle) I can feel it start to fall off (the power), but if I ease up on the throttle I feel it pick back up. I am assuming that this may be a lean condition. I have a check engine light that comes on every once and a great while, I have never had it checked out...Thoughts?
93scbird is offline
post #2 of 6 (permalink) Old 02-28-2010, 01:04 AM
Downbylaw's Avatar
Good start would be...check the code. That's what the OBD system is there for.
Downbylaw is offline
post #3 of 6 (permalink) Old 02-28-2010, 01:14 AM
decipha's Avatar
MAF is my initial guess
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #4 of 6 (permalink) Old 03-01-2010, 08:46 AM
MATLOCK's Avatar
blower belt slip?
All the ponies below are located at my ranch in INDIANA if anyone wants to go for a ride...haha
1989 XR7 SC 5-speed
1996 Bronco on 33's
1995 Mustang GT mild 302 Quicktime Turbo kit 543hp on 9lbs
MATLOCK is offline
post #5 of 6 (permalink) Old 03-12-2010, 09:27 PM
BirdofPrey97's Avatar
Are you running 93 octane or higher? I would do as suggested above and clean the maf, but guessing its pulling timing. Go over to the passenger side and pull the boost plug and drive it and see if it does the samething.
Honor, Grace, and Dignity.....Do you remember these?
BirdofPrey97 is offline
post #6 of 6 (permalink) Old 03-14-2010, 11:34 AM
crash00527's Avatar
Send a message via AIM to crash00527
bad cats? injectors? fuel filter?
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
