Rounded off starter bolts - TCCoA Forums
post #1 of 13 (permalink) Old 03-25-2010, 12:30 PM Thread Starter
Well TCCOA, A SC I hope to be adding to my collection owned by a member here has rounded off starter bolts. How on earth would I go about replacing the starter with rounded bolts? Or would this be something a shop would have to do?
aura1 is offline
post #2 of 13 (permalink) Old 03-25-2010, 12:47 PM
vice grips for the lower one. For the upper one, try hammering on a 12pt socket that is slightly smaller. I think the starter bolts are 1/2" head, so try hammering on a 12mm 12pt socket and see if you can get it off that way.
MadMikeyL is online now
post #3 of 13 (permalink) Old 03-25-2010, 01:02 PM
Craftsman Bolt-Out 5 pc. Damaged Bolt/Nut Remover Set - $15. Works Great.
http://www.sears.com/shc/s/p_10153_1...2061000P?mv=rr
79 TBird 5.0 - wrecked - driven 3 months
79 Mustang Pace Car 4cyl Turbo - sold to collector - driven 1 1/2 years
89 Cougar 3.8 - head gasket @ 141k - driven 1 yr
90 Cougar 3.8 - needed complete front susp @ 159k - driven 4 years
93 Cougar 3.8 - leaky head gasket @ 127k, bad front susp - driven 3 years
95 TBird 4.6 - crashed at approx. 150k - SOLD to TCCOA member to be fixed.
sabarth is offline
post #4 of 13 (permalink) Old 03-25-2010, 01:46 PM
The Band, not the Disease!
AnthraxBird's Avatar
+1
AnthraxBird is offline
post #5 of 13 (permalink) Old 03-25-2010, 03:54 PM Thread Starter
Ahhh you guys are wonderful! Now to only find a write up on how to remove it.
aura1 is offline
post #6 of 13 (permalink) Old 03-25-2010, 04:02 PM
Faster than Porkchop
cjchevez's Avatar
Disconnect the battery , or else sparks will fly. Just in case you didnt know that .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #7 of 13 (permalink) Old 03-25-2010, 04:16 PM Thread Starter
Yeah I learned really quickly about disconnecting batteries when my ratchet grounded out the positive terminal. Spark and messed up hair later I realized you shouldn't do that. Thanks for the heads up though.
aura1 is offline
post #8 of 13 (permalink) Old 03-25-2010, 04:57 PM
1. Tap on the removers (make sure to use the right size)
2. Make sure the tool is all the way on the head of the bolt
3. Repeat step 2...
4. Cautiously turn the tool with even pressure, not to light, and not heavy.
post #9 of 13 (permalink) Old 03-25-2010, 06:57 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I try to beat on a 1/2' 6pt socket and go from there when a 13mm head rounds off. When 10mm does it I use a 3/8 socket. I always use 6pt though, 12pt sockets suck on hex heads.
-Rob
-Rob
Rob is offline
post #10 of 13 (permalink) Old 03-25-2010, 07:07 PM Thread Starter
I'm probably going the bolt-out route. Where is the starter located on a SC? I can not find a thread pertaining to a SC starter to save my life.
aura1 is offline
post #11 of 13 (permalink) Old 03-25-2010, 09:07 PM
bowez's Avatar
+1
This is what I used when I rounded mine thinking they were metric. Replaced them with Allen heads so I can't make the mistake again.
Starter bolts are 3/8-16 which means 9/16 head
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #12 of 13 (permalink) Old 04-14-2010, 10:53 AM
I had the same dang issue when I tried to change my motor mounts about a month ago.....motor mounts never got change. Im headed to sears this weekend
BlackbirdSc94 is offline
post #13 of 13 (permalink) Old 04-14-2010, 10:56 AM
dang just realized this is my first post here, hehe been trolling for about a year now but I post on Sccoa
