Switching from 89SC ABS to conventional, with a twist and need help!!! - TCCoA Forums
post #1 of 3 (permalink) Old 06-05-2010, 02:08 PM Thread Starter
I have a question. If I was going to switch to conventional brakes on my 89 SC, and had access to a 93 SC parts car, could I simply take the brake master cylinder and brake booster from the 93 SC and pipe in my existing brake lines to the 93 ABS master cylinder and just cap off the big pipe that goes to the 93 ABS module? Would that not give me conventional brakes with vacuum boost or am I missing something?
phils88tc is offline
post #2 of 3 (permalink) Old 07-10-2010, 07:48 PM
svtfiend@yahoo.com's Avatar
from what i read on scca, you need a LX booster/master cylinder and resevoir, the block thing that the line goes into and splits and some skill with bending brake line. the lx block has 4 outlets and you only need 3 for a s/c cuz the back runs off one line, not two so you plug the unused hole. the trickiest part i guess is cutting/bending the lines in the engine compartment to fit on the lx one. i will try to find the page for you.
1991 Super Coupe -
Performance=5.0 H.O. w/M5R2 5speed, 3.27 gears w/CF TracLoc,95 Cobra intake, 75mm Power throttle body, fenderwell CAI, C&L 73mm mass air w/24# injectors, FRPP E-Cam,Trickflow spring kit & Crane 1.7 roller rockers on stock E7s, MAC shorty headers, Flowmaster cat back w/hiflow cats, MSD plugs, coil, wires, electric cooling fan, 190lph Walbro fuel pump, BBK pulleys, and a B&M shifter. Drilled/slotted rotors, power brake conversion, Tokico Blues, Eibach springs, tons of poly, T4MO ecm
post #3 of 3 (permalink) Old 07-10-2010, 09:34 PM
Raptor22's Avatar
I know that when I adapted the SC steering rack and brakes to my car I just removed the useless sensors and I was good...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
