ARC Help with the 4.6 swap - TCCoA Forums
post #1 of 6 (permalink) Old 06-08-2010, 03:04 PM Thread Starter
rmfk13's Avatar
What controls the auto ride control system in the Super Coupes? Is it seperate from the rest of the engine wiring harness? I'm dropping a 4.6 in there, out of the same year btw, and still want to take full advantage of the ARC
rmfk13 is offline
post #2 of 6 (permalink) Old 06-08-2010, 05:16 PM
Its all stand alone, the controller and relays are in the package tray and the majority of the wiring is part of what is the EVO harness in LX's. The only circuit I'm not sure about would be the acceleration input, I seem to recall the pcm having an output to the shock module, but I'll have to dig out my EVTM to be sure
post #3 of 6 (permalink) Old 06-09-2010, 02:10 AM
The VSS outputs in parallel to the PCM and the ARC module. The PCM has an output to the ARC module for WOT so that it goes into "FIRM" mode.
post #4 of 6 (permalink) Old 06-09-2010, 06:06 PM Thread Starter
rmfk13's Avatar
OK so if the system is pretty much stand alone, is it all pretty much plug and play or what, will I have to modify anythig or not?
rmfk13 is offline
post #5 of 6 (permalink) Old 06-09-2010, 11:00 PM
If you are putting the 4.6L into your SC, then there's not really anything to plug and play. It's already all there. I'm not sure what you would do in terms of the necessary PCM output to the ARC module, but the system will still work without it. The other thing you'll have to make sure you do is have the EVO solenoid on the 4.6L's power steering pump go the ARC module.
post #6 of 6 (permalink) Old 06-10-2010, 06:31 PM Thread Starter
rmfk13's Avatar
Thanks alot that what I need to know, count that as another vote for mod position
rmfk13 is offline
