Best Gear selection - TCCoA Forums
post #1 of 21 (permalink) Old 09-14-2010, 09:51 AM Thread Starter
Boosted95's Avatar
Best Gear selection
I have a 95SC 5 speed. I was thinking about a ring and pinion change and was wondering if anyone had suggestions. I was thinking about 3.73's and wanted to know if they were to steep for daily driving. Also if you have done this swap, what do I need to look for specifically i.e. splines etc. Will mustang gears work?
Better than Before
Boosted95 is offline
post #2 of 21 (permalink) Old 09-14-2010, 09:53 AM
3.73 for daily driving will be just fine All the other not sure .
post #3 of 21 (permalink) Old 09-14-2010, 10:24 AM
Faster than Porkchop
cjchevez's Avatar
I get about 250 miles per fill up I guess if I push it on Empty I might get 260-270 miles with 4.10's.
It used to be 300 miles. I love the gearing but you do need a Drive shaft and converter change to handle the RPM's on the freeway.Thats if you go past 80mph!
My Pumpkin is from a 99 cobra because you need the 28 spline count that is found on the 99 cobra.
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #4 of 21 (permalink) Old 09-14-2010, 11:42 AM
any 8.8 ford gear will work
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #5 of 21 (permalink) Old 09-14-2010, 12:07 PM
David Neibert's Avatar
Not with a 5 speed....suggest 3.08s or 3.27s.
David
David Neibert is offline
post #6 of 21 (permalink) Old 09-14-2010, 12:51 PM
Didnt some 5 speeds come with 3.31s open non TL from the factory
post #7 of 21 (permalink) Old 09-14-2010, 01:10 PM
Only on the autos. 5 speeds came with 2.73 TL
post #8 of 21 (permalink) Old 09-14-2010, 01:25 PM
Not all (like mine) were TL.
post #9 of 21 (permalink) Old 09-14-2010, 02:08 PM
David
I thought you could go as high as 3.55 with a 5 speed?
post #10 of 21 (permalink) Old 09-14-2010, 02:11 PM
Well I'm still half right
It depends on the gear ratios in the trans and where your shifting, anything higher than 3.27 makes first gear effectively useless in an M5R2 on an SC.
post #11 of 21 (permalink) Old 09-14-2010, 07:15 PM
rmfk13's Avatar
I can vouch for the 2.73's in the 5spd SC's my car is such a dog with them....
Rob
rmfk13 is offline
post #12 of 21 (permalink) Old 09-14-2010, 11:19 PM
DLF
DLF's Avatar
I have 3.55's in my '95 SC now, but that only because I drag race it. IMHO the best gear choice for the street in a stock/mildly modified '94 or '95 SC is 3.27's. Due to the different transmission ratios, 3.08's are a better choice for the '89 to '93 SC's.
And I've tried 2.73's, 3.08's, 3.27's, and now 3.55's over the years.
My Web Site
DLF is offline
post #13 of 21 (permalink) Old 09-15-2010, 07:34 PM
davis97xr7's Avatar
I'm going with 3.31s in the spring for my SC
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #14 of 21 (permalink) Old 09-17-2010, 12:53 PM
Tbird1997's Avatar
wow gear opinions sure take a turn when your talking v8 bird vs SC bird. you post this on the 4.6 section and there all sayin 410 minimum. here looks like 327 for a DD
-Patrick
Tbird1997 is offline
post #15 of 21 (permalink) Old 09-17-2010, 01:00 PM
JR Tigerstar's Avatar
I believe the determining factor is the manual transmission.
JR Tigerstar is offline
post #16 of 21 (permalink) Old 09-18-2010, 10:52 AM
Banned
Send a message via AIM to 1989superchicken Send a message via MSN to 1989superchicken
it's because the 4.6 is a dog in the low end+the gear ratio's in the 5 speed's first gear is really low.
then you add the blower there is no need for any steeper than the stock or 3:27 IN THE 5SPD
1989superchicken is offline
post #17 of 21 (permalink) Old 09-20-2010, 05:46 PM
bowez's Avatar
For the SC.
AOD: 3.55 or 3.73
M5R2: 3.27 max
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #18 of 21 (permalink) Old 09-21-2010, 07:20 PM
Platoribs's Avatar
I've heard stories about how the 3.08 gears yield a nice balance between torque improvements and reducing the effectiveness of 1st gear.
I aim to try this as soon as I can find a source for the gears.
Platoribs House of SHO
95 SHO MTX 73K grn/tan
93 SHO MTX 175K blu/blk
92 SC M5R2 98K Red/Grey tweed ->Blk Cloth SC
89 SC M5R2 112K Blu/Blk Shiny Cobra's! *coming out party, May 20th 2012* Now with moar suspension, brakes and slave cylinder...
91 SC M5R2 100K blk/blk tweed building
86 Mercedes-Benz 300e
Platoribs is offline
post #19 of 21 (permalink) Old 09-21-2010, 08:36 PM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
I had 3.27's in my 90 SC 5 speed and it was sweet! The guy I bought my 3.73 gears from for my Auto had it in his 5 speed and actually lost ET in the 1/4 mile over the 3.27's he had becuase the gears were to short and he had an extra shift before he crossed the line.
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #20 of 21 (permalink) Old 09-23-2010, 11:15 PM
Stryker's Avatar
Listen to Niebert. Anything more than 3.27's and first gear is useless. This is a 3.8SC stick fella's, not a 4.6 auto....
Mods: The usual stuff... 3.73 Gears, J-mod, catless mandrel 2.5" true duals, Marauder Converter, Eibachs, Xcal2 and Phoenix Gold Audio, chrome 18's, etc. etc..
I joined the dark side...
2002 Mustang GT, FRPP Aluminator with Tork Tech MP112 intercooled S/C at 17PSI, with all the supporting mods.
Stryker is offline
post #21 of 21 (permalink) Old 09-24-2010, 10:09 AM
I know this doesn't apply to the original question, but I was doing some comparisons between a 4R70W and T45 gear ratio vs rear end gear vs final drive ratio in each gear (and rpm at 75 mph)
(Sorry, but I don't know how to insert this as a table)
4R70W (245 50 17)(26.64”)
Transmission ratios:
First: 2.84
Second: 1.55
Third: 1.00
Fourth: 0.70
RPM @ 75 MPH
3.27 9.29 5.07 3.27 2.29 2165
3.73 10.59 5.78 3.73 2.61 2470
T45 (245 50 17)(26.64”)
First: 3.37
Second: 1.99
Third: 1.33
Fourth: 1.00
Fifth: 0.67
RPM @ 75 MPH
2.73 9.20 5.43 3.63 2.73 1.83 1730
3.08 10.38 6.13 4.10 3.08 2.06 1952
3.27 11.02 6.50 4.35 3.27 2.19 2072
3.55 11.96 7.06 4.72 3.55 2.38 2250
3.73 12.57 7.42 4.96 3.73 2.50 2364
And why I posted this:
http://forums.tccoa.com/showthread.php?t=131569
Just thought I would add that so people can see one way to compare how their car will change based on a gear ratio change or transmission change.
69 F100 LWB w/460 Engine
