1990 Sc - TCCoA Forums
post #1 of 4 (permalink) Old 02-01-2011, 02:17 PM Thread Starter
tbirdsps's Avatar
1990 Sc
Ooh, Ooh! I might have found a 90 SC 5 speed manual locally. I'm waiting for a response.
Anything in particular I should watch out for?
tbirdsps is offline
post #2 of 4 (permalink) Old 02-01-2011, 02:44 PM
Motor mounts, were head gaskets done, vacuum leaks, coolant leaks, any rod knock, check for any wobble on the harmonic balancer, does the tach work properly, synchros for 2nd and 3rd gears does the ARC work, wear on the driver's side bolster, do all the functions of the seats work (6-way adjustment plus bolsters and lumbar, and make sure bolsters and lumbar don't leak), front ball joints and strut rod bushings, check for rust behind the ground effects, if it has a sunroof, does that work properly and not leak, do the auto seat belts work.
post #3 of 4 (permalink) Old 02-01-2011, 03:35 PM
I think he said it all.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #4 of 4 (permalink) Old 02-01-2011, 05:15 PM Thread Starter
tbirdsps's Avatar
Yup, I have a good list thanks to MadMikeyl I don't know the miles on it yet and haven't seen it yet.
tbirdsps is offline
