Fuel Gauge Reads Low....or the worst mpg? - TCCoA Forums
post #1 of 6 (permalink) Old 02-10-2011, 11:15 AM Thread Starter
The check gauges light comes on for low fuel.....yet it only take 12 gallons to fill it. I replaced the fuel pump/sender assembly.....same issue.
Pulled the dash, everything was plugged in.
Seems like its about a 1/4 of a tank off.....200 miles of highway driving and then the tank shows empty.
Any ideas? How do you check the gauge itself?
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #2 of 6 (permalink) Old 02-10-2011, 12:19 PM
Yea if you only added 12 gallons you should of had 6 still in the tank for a total of 18. Was it doing this before the new fuel pump/sender. It sounds like it was but just making sure. Which one of your birds is having the problem. Have you tried swapping gauges yet.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #3 of 6 (permalink) Old 02-10-2011, 12:22 PM Thread Starter
The reason I swapped the pump was to fix the problem. Its the 95 sc that's doing it.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #4 of 6 (permalink) Old 02-10-2011, 03:41 PM
90coug's Avatar
I have this same issue, it didn't happen until after I replaced the fuel pump for a bigger one.
I've always chalked it up to a bent floater, reaplacing the gauge did not help.
'95 SC
90coug is offline
post #5 of 6 (permalink) Old 02-10-2011, 09:40 PM Thread Starter
That's what I thought, hence why I replaced the pump and sending unit......its annoying that's all.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
post #6 of 6 (permalink) Old 02-22-2011, 11:38 PM
crash00527's Avatar
Send a message via AIM to crash00527
I have the same exact problem!!
It actually started happening the same day after i put in a new tranny. For some reason my fuel gauge, coolant temp. gauge and dash temp. reader are all out of whack a but bit... very weird. Still haven't really researched it to find out more
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
