Ignition Control Module? 3.8S/C - TCCoA Forums
post #1 of 17 (permalink) Old 08-31-2011, 02:11 PM Thread Starter
My local supplier does not have the adapters to check the module. Here are the symptoms. Tach goes dead, runs rough, either missing, or misfiring 2-3 cylinders, sometimes hard starting.
Faust is offline
post #2 of 17 (permalink) Old 08-31-2011, 02:54 PM
pettyfog's Avatar
The best tester is a known good distributor. Dont even have to stick it in the engine. Put a plug on the coil HT lead.
Your dist pickup may be bad, you know.
Pull the ICM off the frame/heat sink. If the dielectric grease is dried/caked it is most likely bad.
And I would rather have a motorcraft ICM off a rusted out hulk in the junkyard than a new wells/Airtex from a box. As long as that grease is still grease.
pettyfog is offline
post #3 of 17 (permalink) Old 10-08-2011, 11:35 PM
Cam/crank sensor! 3.8 s/c don't have a distributor.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #4 of 17 (permalink) Old 10-09-2011, 12:52 AM
or it maybe the DSI also.
1992 sport, m5r2 swap. Next, headers and exhaust
1991 super coupe. Five speed. New motor mounts and a few performance parts coming
1990 super coupe auto. Needs new crank
Plus a few parts cars
schwalbe is offline
post #5 of 17 (permalink) Old 10-09-2011, 12:06 PM
decipha's Avatar
since it's running rough its a bad DIS module, must be 89-93 supercoupe
94-95 has edis and doesn't encounter that problem, ford did do something right
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #6 of 17 (permalink) Old 10-09-2011, 03:19 PM Thread Starter
Yes, it is a '90 Cougar XR-7, same as S/C. Don't even know what a DIS is. Here arethe symptoms. Every once and awhile it will start to run rough, I would say misfiring. The tachometer goes dead. If I pull over to the side ofthe road, trun it off and restart, everything is fine for a while. When cold, it starts right up. Hot it can take 3-4 tries to start.
Faust is offline
post #7 of 17 (permalink) Old 10-09-2011, 04:35 PM
It is nice
im pretty sure if i remember right there was a tsb on the ICM for overheating in 90'
91CougarLS is offline
post #8 of 17 (permalink) Old 10-09-2011, 09:02 PM
pettyfog's Avatar
Ooops on the Distributor... well, whatever this is a classic ICM fail symptom much like later TSI problems. { Earlier ones just died, period}
So if it's not the ckps or cps, and it probably isnt, look for dried grease on the back. If it is dry, it's almost certainly the problem. If not dry still could be.
pettyfog is offline
post #9 of 17 (permalink) Old 10-10-2011, 05:03 PM
bowez's Avatar
Sounds like bad Cam sensor to me. If was bad Crank it wouldn't start at all. With bad cam sensor it will lose tach but still run.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #10 of 17 (permalink) Old 10-10-2011, 07:39 PM
Agreed. that was the culprit on my SC months back.
post #11 of 17 (permalink) Old 10-27-2011, 10:32 AM
Remove DIS clean heatsink mount and back of DIS apply Artic Silver heatsink coumpound and reinstall . Best place I have found to get Artic Silver is computer shop .
JKJ454 is offline
post #12 of 17 (permalink) Old 10-27-2011, 10:56 AM
pettyfog's Avatar
Which aint gonna fix a damaged DIS, if that's what it is and hard starting says it might be. And "Artic Silver heatsink coumpound" is overkill, but wth..
pettyfog is offline
post #13 of 17 (permalink) Old 10-27-2011, 01:42 PM
dDUBb's Avatar
You dont own a SC, so how would you know what the common remidies are ?????
Just put yer distributor in there ... hahaha, sorry that AINT gonna werk, aint is not a real word, by the way ..
dDUBb is offline
post #14 of 17 (permalink) Old 11-14-2011, 06:13 PM
Triston's Avatar
Hi Faust-
I just went trough the same exact issues & symptoms. The DIS is Distributorless Ignition System. I replaced the ICM (ign control mod) for $130 and still had the problem. Next I bought a cam position sensor from autozone for $38 and that did it. The cam position sensor is right under the blower snout just to the pass side. I'd try just the cam sensor before dropping $130 on the ICM.
I'm willing to bet that'll solve your problem.
1995 Thunderbird LX 4.6L, T45
1989 Thunderbird SC 3.8L..... SOLD
1964 Falcon HT 302/C4
1984 Girlfriend, Low Miles
You don't tear off your knuckles writing a check every month!!
Triston is offline
post #15 of 17 (permalink) Old 11-22-2011, 01:37 PM
Originally Posted by Triston View Post
Hi Faust-
A 1990 3.8L does have a distributor and does NOT have DIS.
It doesn't have a crank sensor either. The pickup is in the distributor.
~Rick
TCCoA Sig
post #16 of 17 (permalink) Old 11-22-2011, 11:14 PM
Just for completeness - the 3.8NA (Normally Aspirated) is distributored, the 3.8SC (Supercharged) has the DIS.
RalphP is online now
post #17 of 17 (permalink) Old 11-23-2011, 06:40 AM
Yep my 90 SC has the DIS.
