SC ignition question - TCCoA Forums
post #1 of 8 (permalink) Old 10-02-2011, 06:36 PM Thread Starter
Triston's Avatar
I've got an ignition problem with my '89 SC... I went through right when I bought it last December and put in new plug wires, coil pack and plugs. Earlier this summer the car started jerking violently like the ignition was cutting out. Whenever it would jerk, the tach also drops off and is non-operational there's really no pattern to it but it won't happen on a cold engine. Sometimes it'll continue for 3-4 minutes, sometimes I'll take the car out and it won't do it at all.
I replaced the ignition control module yesterday but the problem is still there.
Has anyone ever experienced symptoms like this?
1995 Thunderbird LX 4.6L, T45
1989 Thunderbird SC 3.8L..... SOLD
1964 Falcon HT 302/C4
1984 Girlfriend, Low Miles
You don't tear off your knuckles writing a check every month!!
Triston is offline
post #2 of 8 (permalink) Old 10-02-2011, 06:41 PM
Could be the camshaft or crankshaft sensor going bad, Just a thought .
post #3 of 8 (permalink) Old 10-02-2011, 11:08 PM Thread Starter
Triston's Avatar
Ran to Autozone and grabbed a cam position sensor. Swapped it out and went for a drive, got it up to temp and the problem never showed up.
Thanks for the suggestion Thunder Checken!
Triston is offline
post #4 of 8 (permalink) Old 06-21-2013, 11:47 AM
Josh52894's Avatar
I have a similar problem, It jerked badly and died once, jerked badly again and now its cut out and wont start at all. I remember seing the Crank pulley wobbling at idle back when it ran so i beleive it is the CKP sensor. I have disasembled the CMP and everything looks fine even new. have not checked the DIS.
85 Pontiac Fiero 2.5L auto RIP
86 Pontiac Fiero 2.5L five speed RIP
90 Ford Thunderbird Supercoupe 3.8 5 speed DD
99 Crown Vic police interceptor 4.6 auto
Josh52894 is offline
post #5 of 8 (permalink) Old 06-21-2013, 12:40 PM
May not actually be the CKP sensor - the crank pulley wobbling means the dampener has failed. It's time to buy a BJP (?) balancer, and while it's off, go ahead and replace the CKP sensor in case the failing balancer damaged it.
But the key note is, you'll need a new balancer.
RalphP is offline
post #6 of 8 (permalink) Old 06-21-2013, 01:09 PM
Yup, wobbling crank pulley means the balancer failed. The replacement one to get is made by BHJ. If the car won't start at all, the failing balancer probably damaged the crank sensor, so replace that at the same time. Also the factory balancer and crank pulley are matched and neutral balanced together. The BHJ will be neutral balance on its own, and if the crank pulley itself is out of balance, it could cause damage to your engine, so you will need to at the very least have the crank pulley checked for neutral balance, or now would be a good time to order a set of underdrive pulleys and install them at the same time.
post #7 of 8 (permalink) Old 06-23-2013, 08:46 AM
fyi if you keep running it the ballance bolt WILL break off in the crank,i know for a fact.Been there.
sleeper bird is offline
post #8 of 8 (permalink) Old 11-08-2013, 12:43 PM
Josh52894's Avatar
im through it now, I went stock replacement crank pully and balencer because I didnt have a place to stay and couldnt get anything ordered online. oh well.... the pully vibrates ever so slightly and makes me nervous but at least if it breaks this time I will have the opurtunity to upgrade. as i could see that was the cars second balencer done with an unmatched pully.
