input needed - TCCoA Forums
post #1 of 5 (permalink) Old 11-26-2011, 12:28 PM Thread Starter
input needed
I am going to be doing the head gaskets in my 93sc this coming spring and while I have tore down I was thinking of doing the camshaft. My question is. are there better factory heads than the 93. And what ever else may be better to swap out at the time of being tore down. Also what camshaft would be a decent replacement that would give it a little more umph. Would like to do more but I am sure money will be an object. I would also like to go with a shorter gear but don't know which is in it stock. Was thinking about a 3.23-3.55 gear. Input?
Bryon.
93scbird is offline
post #2 of 5 (permalink) Old 11-26-2011, 12:35 PM
Is your sc auto or stick. The stick had 2.73 gears the auto have 3.27. Your best option on heads is to have the ones you have ported and polished and have oversized valves put in. As for the best cam I don't know on that one.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #3 of 5 (permalink) Old 11-26-2011, 12:40 PM Thread Starter
automatic trans. also I did do the exhaust awhile back with dual magnaflows in the stock location with a x-pipe and stock cats for the time being.
bone stock 93' super coupe, automatic trans
dual magnaflow exhaust with x-pipe and stock cats, atm.
93scbird is offline
post #4 of 5 (permalink) Old 11-26-2011, 12:41 PM
I know. Pop over to www.sccoa.com/forums , check out the previous notes, and then talk to Dave Dalke over there - he's as smart on SC cams as Nick is on mod motor cams. Or at least, they are both so far above MY head that they look equally genius
RalphP is offline
post #5 of 5 (permalink) Old 12-04-2011, 08:12 PM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
If you do any aftermarket cam upgrade you are going to have to get new injectors and a tune to go with it. I did a medium cam on my 94 that already had the factory 36lb injectors and when I put it on the dyno to be tuned it was out of injector by 4000 rpm.
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
