Power Steering Pulley - TCCoA Forums
post #1 of 8 (permalink) Old 01-16-2012, 06:39 PM Thread Starter
I need some help. Broke the power steering pulley while removing it from the car. I needed to change the pump out. Any idea where I can get one. The junk yards here are a no go so far. I am in Jacksonville Fl.
dually is offline
post #2 of 8 (permalink) Old 01-16-2012, 07:07 PM
http://www.ebay.com/itm/YR3Z3A733AA-...ht_2067wt_1002
Assuming that is for the 1995 3.8L in your info.
~Rick
TCCoA Sig
post #3 of 8 (permalink) Old 01-16-2012, 11:05 PM
dDUBb's Avatar
It needs to be an 8 rib pulley - the Ebay one is only 6.
I might have one in storage if you cant find one ...
dDUBb is offline
post #4 of 8 (permalink) Old 01-17-2012, 02:08 PM
I have a spare off of a 91 sc if it is the same. Pm me if interested.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #5 of 8 (permalink) Old 01-20-2012, 08:27 PM Thread Starter
Thank you for the replies i had to go out of town for a few days. I am going to check a ford only junk yard in the morning if they don't have on I will pm you.
dually is offline
post #6 of 8 (permalink) Old 01-21-2012, 12:24 PM Thread Starter
no luck at the yard PM's sent thanks again.
dually is offline
post #7 of 8 (permalink) Old 01-21-2012, 02:21 PM
Jeff Bratton's Avatar
Send a message via AIM to Jeff Bratton
I have a couple as well for cheap!!
Thx.
Jeff B.
'89 Black SuperCoupe
Louisville, Ky.
260 RWHP / 349 RWTQ
Email me: [email protected]
Powered By Magnum Powers MPIII & other Bolt-On's
Check out My SuperCoupe
Jeff Bratton is offline
post #8 of 8 (permalink) Old 01-21-2012, 03:44 PM
dDUBb's Avatar
.. obviously, its a buyers market
dDUBb is offline
