Missing temp sensor - TCCoA Forums
post #1 of 9 (permalink) Old 04-12-2012, 06:03 PM Thread Starter
cruising
Missing temp sensor
The previous owner of this car had removed the sensor right under the throttle body. Before i put one back in, is their any problems with leaving it the way it is?
Zack
BigZ is offline
post #2 of 9 (permalink) Old 04-12-2012, 07:42 PM
renello79's Avatar
This is for the auto climate control if I'm not mistaken
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #3 of 9 (permalink) Old 04-13-2012, 01:52 AM
dDUBb's Avatar
Yeah its for the EATC / Air conditioner, the Cold Engine lockout switch. Prevents blower operation when heating is required and coolant temp is below 120 degrees. If your AC isnt working properly you can just ground it and it will be fine.
dDUBb is offline
post #4 of 9 (permalink) Old 04-14-2012, 04:03 PM Thread Starter
cruising
Alright, good deal. I don't have the a/c hooked up right now anyway so its staying off. Thanks
Zack
BigZ is offline
post #5 of 9 (permalink) Old 04-14-2012, 04:21 PM
Actually, the CELO doesn't affect the A/C, but the heat.
Its purpose is to keep the EATC from demanding high fan to heat the car until there's some heat available.
RalphP is offline
post #6 of 9 (permalink) Old 04-14-2012, 04:34 PM
While in the AUTO selection only.
post #7 of 9 (permalink) Old 04-14-2012, 06:14 PM
True. However, if I put the blower on something besides "AUTO", I'm the one demanding the fan speed, not the controller
But point taken for correction.
RalphP is offline
post #8 of 9 (permalink) Old 11-12-2012, 03:44 PM
92LX5.0's Avatar
I know this thread is a little old but I didnt see the need for a new thread when this answers half my question.
What im still curious about the cold engine lock out is if the A/C has been disconnected should this still function properly on the heater circuit?
My car tries blowing full speed right at start up if its on "Auto". Is it a switch issue or due to the A/C not functioning properly?
92LX5.0 is offline
post #9 of 9 (permalink) Old 11-12-2012, 08:19 PM
It's not for the A/C, but the HEATER.
So if it's not connected, you'll get full fan as soon as the ECC boots up.
RalphP is offline
