Advice 3.8 sc 90 - TCCoA Forums
post #1 of 9 (permalink) Old 07-07-2012, 01:30 PM Thread Starter
Advice 3.8 sc 90
I am having trouble with my 1990 tbird sc trying to rebuild. But stuck on heads
Xr7tbirdsc is offline
post #2 of 9 (permalink) Old 07-07-2012, 01:31 PM
What's your question?
post #3 of 9 (permalink) Old 07-07-2012, 02:08 PM
dDUBb's Avatar
Have the heads Re-surfaced no matter what you do. If you want to use MLS gaskets you need to surface the block also.
Use the ARP Head studs, 3.8 specific may require grinding on the exhaust manifolds, chase the threads in the block with the appropriate size tap. Or use the Chevy 2.8 Head studs, same diameter but they are shorter, less expensive and clear the exhaust no problem.
dDUBb is offline
post #4 of 9 (permalink) Old 07-07-2012, 03:05 PM
I'll add that the best resource for SCs is over at SCCoA - www.sccoa.com/forums .
(Oh, pipe down! I keep pointing people HERE for non-SC stuff over there!)
RalphP is offline
post #5 of 9 (permalink) Old 07-08-2012, 11:07 AM Thread Starter
My question would be anything that would help on rebuilding i am a first timer and dont want to destroy it the person i bought it from said the rod was shot but the sound says different i know i need a valve spring compressor to get the heads off i will get the heads resurfaced but my main focus is taking the engine apart and understanding the sc dynamics i have fell in love with these engines and want to know everything aboit them i would like blown up diagrams if its possible but any advice will help
post #6 of 9 (permalink) Old 07-08-2012, 11:27 AM
Gotcha.
These are non-SC exploded view diagrams, but will give you a general idea of what you'll find: http://forums.tccoa.com/showthread.php?t=138288
post #7 of 9 (permalink) Old 07-08-2012, 12:03 PM Thread Starter
Gotcha.
will these diagrams work for a 1990 tbird?
post #8 of 9 (permalink) Old 07-08-2012, 12:26 PM
It's a basic rundown. It is most certainly worth the money to invest in one of these... you may want to consider getting one: http://www.ebay.com/itm/1990-FORD-TH...#ht_500wt_1180
post #9 of 9 (permalink) Old 07-11-2012, 03:12 PM
David Neibert's Avatar
You don't need a valve spring compressor to get the heads off. Suggest buying a Haynes or Chilton repair manual to get most of the info you are seeking.
David
David Neibert is offline
