Any advice for doing the timing cover on a 89 sc? - TCCoA Forums
post #1 of 10 (permalink) Old 08-09-2012, 07:05 AM Thread Starter
renello79's Avatar
I have an idea of what I have in store for me, but any tips would be great.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #2 of 10 (permalink) Old 08-09-2012, 01:12 PM
If I remember right. There is a Allen bolt in the lower right hand side of the time cover. Don't miss it or you might snap your timing cover.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #3 of 10 (permalink) Old 08-09-2012, 02:33 PM
Also now is a good time to get a BHJ balancer. Most of the cases of the SC balancer falling apart come from when it is removed and reinstalled, and if it falls apart, getting the remaining sleeve off the crank will be a major PTIA.
post #4 of 10 (permalink) Old 08-09-2012, 02:48 PM Thread Starter
renello79's Avatar
I have already had to do the balancer, (no fun) and unfortunately I don't have the money to get the bjh balancer at the moment. Thanks for the heads up on the bolt. Any suggestions on the cam sensor?
Phrum Steve
sold, sadly
post #5 of 10 (permalink) Old 08-09-2012, 03:32 PM
Set the motor to #1 TDC compression, and with a paint marker make a line that goes across the shutter in the sensor, the sensor housing, and the timing cover. When you put it back together, make sure it is back at #1 TDC compression, and make sure all the marks line up, and you will be good to go.
Or they make a tool that clips in the top of the sensor body and holds it in place properly aligned to reinstall it.
post #6 of 10 (permalink) Old 08-09-2012, 04:53 PM
bowez's Avatar
Mike, its 26° ATDC will line up with the notch in the balancer.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #7 of 10 (permalink) Old 08-09-2012, 05:44 PM Thread Starter
renello79's Avatar
Do I need to remove the sensor before pulling the cover?
Phrum Steve
sold, sadly
post #8 of 10 (permalink) Old 08-13-2012, 06:38 PM
Allan's Avatar
To back up Mike's statement, we got 13 months out of the reinstalled balancer before it ruined the crank snout in my son's '94 SC. We reinstalled it perfectly and it still self-destructed. The stock SC balancers (at least the '94's) are sort of like those tourque-to-yeild head bolts that can only be installed once.
Do the repair now but start saving for the BHJ immediately. Try to get one and install it in the next few weeks or couple of months at the most. It would suck to ruin the engine because of a balancer failure.
Oh and good luck on your repair.
92 Sport -5.0L
Rolling on 17s, long tubes and a "To-Do" list
97 Sport -4.6L
Rolling on 17s, SOLD but not forgotten
15 Scat Pack -M6
Rolling on 20s... like that means something
Non-Official Parts Hoarder
Cars, guitars, cigars, etc.
Allan is offline
post #9 of 10 (permalink) Old 08-13-2012, 06:45 PM
Werd. The BHJ is one of those "just suck it up" expenses that pays for itself in spades in the long run.
And as I recall you already had to deal with balancer failure and had to remove the sleeve already. You really want to go through that again when it does indeed happen again?
post #10 of 10 (permalink) Old 08-13-2012, 07:36 PM
bowez's Avatar
Yes, the gears mesh with the cam gear. Mark all positions before you remove the sensor--even take a picture.
93 SC Tbird
93 5.0 Tbird
bowez is offline
