Which sender is for temp guage? - TCCoA Forums
post #1 of 15 (permalink) Old 11-12-2012, 03:53 PM Thread Starter
92LX5.0's Avatar
Im looking for the coolant temp sender that operates the temp guage on my 90 s/c parts car. There is no interior left in the car right now so grounding the wire doesnt help much.
I just wanted to swap the sender into my LX but want to make sure its the correct one and not the temp lock out switch or something. Unless they are the same part?
None of the local parts stores have the sender in stock and its getting colder so I'd like to fix it before its too cold.
92LX5.0 is offline
post #2 of 15 (permalink) Old 11-12-2012, 05:45 PM
Rayo's Avatar
Coolant Sender
This is the ECT Coolant Temp Sender (for PCM)..
This is the Coolant Temp Sender for the Temperature Gauge..
The 1 Wire "Coolant Temp Sender for the Temperature Gauge" on your 90 s/c parts car..
Is the same as the "Coolant Temp Sender for the Temperature Gauge" on your 92 5.0..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 15 (permalink) Old 11-12-2012, 05:49 PM Thread Starter
92LX5.0's Avatar
Thank you.
You seem to be a walking T-bird encyclepedia.
All the help and info is greatly appreciated.
92LX5.0 is offline
post #4 of 15 (permalink) Old 11-12-2012, 08:18 PM
I'll add that I wouldn't reuse the old one - there's a nice TSB on ALL of them failing due to a manufacturing design defect. Well, not all have failed, but it's more like "not all have failed YET"
Get a new one instead. They're cheap, and cheap insurance against burning up a motor because the temp gauge pointed to "N" when it was at 270*F ...
RalphP is offline
post #5 of 15 (permalink) Old 11-13-2012, 04:52 PM Thread Starter
92LX5.0's Avatar
I am only looking to use it until the local parts place can get one in. I just dont really like not having a temp guage. But good to know there is a TSB on them. Did it affect the cold engine lock out sender switch for the heater as well?
They look like they could be the same senders.
92LX5.0 is offline
post #6 of 15 (permalink) Old 11-14-2012, 01:10 AM
It didn't, and they're not.
The CELO is a switch that opens on temperature rise.
The gauge sending unit is a thermistor that changes the value on temp rise.
RalphP is offline
post #7 of 15 (permalink) Old 11-14-2012, 02:18 PM Thread Starter
92LX5.0's Avatar
Hmmm, is it common for both to be dead?
92LX5.0 is offline
post #8 of 15 (permalink) Old 11-14-2012, 08:49 PM
Hi my gauge died just before killing the rest of the engine of in overheat. Might be common.
danielcah is offline
post #9 of 15 (permalink) Old 11-14-2012, 10:29 PM
Well, 100% of my cars have had both die
However, there's a TSB on failures in the temp sender - not so much on the CELO switch.
Besides, unplug the CELO and all you get is cold air first thing in the winter. That's not a show stopper.
RalphP is offline
post #10 of 15 (permalink) Old 11-14-2012, 10:33 PM Thread Starter
92LX5.0's Avatar
I just turn my fan to a low setting off auto. But I figured if im changing the heater coolant tube anyway I may as well fix the CELO at the same time.
92LX5.0 is offline
post #11 of 15 (permalink) Old 11-14-2012, 11:36 PM
Well, if you find one, let me know.
Mine is bad, so I have a plug in the hole now and no sensor.
RalphP is offline
post #12 of 15 (permalink) Old 11-14-2012, 11:40 PM Thread Starter
92LX5.0's Avatar
Are they a discontinued part?
92LX5.0 is offline
post #13 of 15 (permalink) Old 11-14-2012, 11:48 PM
Found one by searching part number on Ebay Part : 9U2Z 12A648-A For the management
http://www.ebay.com/itm/COOLANT-TEMP...89e1c9&vxp=mtr
And this is for a Gauge,
http://www.ebay.com/itm/TEMPEATURE-S...461942&vxp=mtr
post #14 of 15 (permalink) Old 11-15-2012, 12:07 AM Thread Starter
92LX5.0's Avatar
I ordered a new one for the guage the other day, just waiting on it to come in. Hadnt thought to check availability on the CELO. I do have a couple from donor cars that had working climate control though.
92LX5.0 is offline
post #15 of 15 (permalink) Old 11-15-2012, 06:51 AM
Neither one of those is the CELO switch.
The two temp sensors (gauge and ECU) are readily available.
RalphP is offline
