Oil Filter Comes Loose After Oil Change - TCCoA Forums
post #1 of 17 (permalink) Old 02-24-2014, 10:27 AM Thread Starter
Stroked and Blown
BlakTbird96's Avatar
95 SC motor. I always do my own oil changes and I was told to never tighten the filter too much which I do not. I hand tighten it, then just a little jerk with oil filter wrench to make it snug. The first drive after the oil change, I get a small oil leak and coolant leak coming from oil filter & oil cooler area. I put car on ramps and have to tighten the oil filter again. Then the problem is fixed until next oil change. Do the filters have a tendency of coming loose the first time engine is hot after the oil change?
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #2 of 17 (permalink) Old 02-24-2014, 10:31 AM
I lubricate the o-ring on the new filter with fresh oil, then tighten it about 3/4 turn past the point where I can feel it start to snug up. Hand tight every time, and I've never run into issues.
Coolant leak? There shouldn't be any coolant coming from the oil filter area unless there are problems elsewhere.
post #3 of 17 (permalink) Old 02-24-2014, 10:42 AM Thread Starter
Stroked and Blown
It's just a minor coolant leak after oil changes...i think it may be because the oil filter isn't tightened enough against the oil cooler? I don't know. After I tighten the filter again, there is no coolant dripping. Coolant does run through the oil cooler, doesn't it?
My other home:
Mid-AtlanticMN12's
post #4 of 17 (permalink) Old 02-25-2014, 03:31 PM
ricklovin93's Avatar
coolant and your oil filter have no relation. No coolant goes in to the filter. As for the oil filter tighten that sucker down. Dot use a tool to tighten it though. Get it as tight as you can by hand. I dont follow the instruction on the oil filter box "1/4 turn after the gasket makes contact" or whatever. Never had a filter get stuck, never had one leak.
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #5 of 17 (permalink) Old 02-25-2014, 04:32 PM
Sounds like your oil cooler o rings are bad, never had one do that
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #6 of 17 (permalink) Old 02-25-2014, 07:30 PM
Mgino96tbird46's Avatar
I hand tighten mine and turn an additional 1/2 rotation. Never had any problems this way.
Mgino96tbird46 is offline
post #7 of 17 (permalink) Old 02-26-2014, 11:58 PM
I make stuff
I think I tend to over-tighten mine. I'm always paranoid about it coming loose and dumping the oil out without me knowing...
98mark8lsc is offline
post #8 of 17 (permalink) Old 02-27-2014, 10:52 AM
I'd rather have to bust my ass getting a filter off, then have an engine seize up going down the highway from it loosening itself up.
post #9 of 17 (permalink) Old 02-27-2014, 04:54 PM
Urambo Tauro's Avatar
I've never had a filter loosen up unless it was loose to begin with. You're sure you don't have an old filter gasket remnant staying behind?
You do your own oil changes so I don't want to insult your technique. That said, there are some out there who never developed certain habits like oiling the filter gasket prior to install. (it's happened) Besides that, you only need a clean surface for the gasket to mate to, and don't cross-thread. If these 3 things are done right, I cannot imagine the filter coming loose unless something is disturbing it. Vibrations...?
Urambo Tauro is offline
post #10 of 17 (permalink) Old 02-27-2014, 05:17 PM
Jimmy 2Coupes's Avatar
I have always spun the new filter on until I feel the rubber gasket making contact with the filter housing and then go one full turn afterward. Part of that full turn I can do be hand but the rest I use a ratchet and filter tool. Never had a oil leak on my SC's that way.
1995 SC (five speed)
Best E.T. [email protected]
Best MPH [email protected]
Best 60' 1.7489
1994 SC (automatic) [email protected]
On a stock long block with bolt on's
Sweet SC, lower13's coming.
Jimmy 2Coupes is offline
post #11 of 17 (permalink) Old 02-27-2014, 05:22 PM Thread Starter
Stroked and Blown
Thank you. I will check that. I know coolant does not run through the oil filter but it does the oil cooler, correct? That's what i was trying to explain.
My other home:
Mid-AtlanticMN12's
post #12 of 17 (permalink) Old 02-27-2014, 06:19 PM
Yes there is coolant running thru the oil cooler. Make sure the hose clamps are tight on the hoses to the cooler. Better check your dipstick to after you run the car to make sure the oil isn't milky looking. If it is then there is a leak in the cooler getting to your oil which is very bad. Not that I have ever seen an oil cooler go bad.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #13 of 17 (permalink) Old 02-27-2014, 07:26 PM Thread Starter
Stroked and Blown
Ok. I will check to make sure hose clamps are tight. If they are loose, would that cause coolant to leak from that area? The coolant leak seems to stop after I tighten the oil filter though so would that be the hoses or the oil cooler itself leaking if the coolant leak stops after oil filter is tightened?
Oh, and if i have to buy a new oil cooler for this thing, do i have to drain the coolant system to replace it? Not sure how much coolant would leak out. And, if the oil cooler has been leaking for quite some time, what are the chances that the engine is phucked? I rather not invest to get the lean code figured out via an SCT dealer, and get the suspension replaced if the engine is done.
My other home:
Mid-AtlanticMN12's
post #14 of 17 (permalink) Old 02-27-2014, 08:38 PM
Righting oil filter has nothing to do with coolant leak, also if the oil filter is tightened to begin with it don't come loose, I've been working on cars for over 10 years and I've ever seen a filter come,
10.75 @128.38
RobertP is offline
post #15 of 17 (permalink) Old 02-27-2014, 08:44 PM
Do you ever see any coolant come out first when you change the oil?
BLOWN38 is offline
post #16 of 17 (permalink) Old 02-27-2014, 08:47 PM
When you take the filter off make sure the big nut is tight that holds the cooler on. It is where the threads are that the filter screws to has a hex at its base. It could be loose and moving around causing the hoses to leak and when you tighten the filter it tightens everythng up.
BLOWN38 is offline
post #17 of 17 (permalink) Old 02-28-2014, 05:59 AM Thread Starter
Stroked and Blown
no. i've never noticed coolant leak at oil changes. Just seems to be when the oil filter wasnt snug against the oil cooler enough.
My other home:
Mid-AtlanticMN12's
