Head Gasket Replacement - TCCoA Forums
post #1 of 4 (permalink) Old 03-19-2014, 08:36 PM Thread Starter
I am in the process of doing a head gasket on a 1990 super coupe. I am at a point now where I am stuck. I can't seem to figure out how to get the bracket for the fuel rail/pressure regulator loose from the back of the engine. In looking at alldata and various pics online, the bracket appears to be attached with one nut on a stud. I have removed that. But the bracket still won't slide free. Until then I can't remove the last bolt on the intake and proceed any farther. Can anyone please give me some insight on what is the process for removing this stubborn bracket? Thanks in advance. Really want to get this car running again, its a 5speed.
marc1971 is offline
post #2 of 4 (permalink) Old 03-19-2014, 11:06 PM
dDUBb's Avatar
I dont recall a stud being back there .. the bracket for the fuel rail is attached to the back of the drivers side head with a 10mm bolt.
dDUBb is offline
post #3 of 4 (permalink) Old 05-05-2014, 05:02 PM
Formula 1 Freak
SuperCoupe's Avatar
My 90 was a stud with 2 nuts….and it was a huge PITA. Someone had told me about it before I started, but it was still a ***** to get at. I dunno if maybe some have bolts and some have studs, but I'm pretty sure mine had the stud with two nuts. I'd suggest using a small telescopic mirror to get a look at it
common sense...
so rare,
it's kind of like
a super power
SuperCoupe is offline
post #4 of 4 (permalink) Old 05-05-2014, 08:19 PM
BJL
Send a message via AIM to BJL
there was a stud for a bracket to the water pipes and then a stud for the fuel rail when i changed the Fuel pressure regulator on my cougar 2 months ago. but yes. pain in the ass. i ended up using a stubby wrench.
Brian J Larkin
1988 Tbird TC 5spd. few bolt ons, 308k miles
1989 Cougar XR7 AOD 110k
BJL is offline
