What maf should I use? - TCCoA Forums
post #1 of 4 (permalink) Old 05-14-2014, 10:38 PM Thread Starter
visnich020612's Avatar
Ok I have a 93 sc I'm in the process of building it. It will be portmatched with a 2.7 pulley on the stock blower my question is what maf and throttle body should I use.
visnich020612 is offline
post #2 of 4 (permalink) Old 08-08-2014, 07:49 PM
Formula 1 Freak
SuperCoupe's Avatar
if you change the MAF to anything other than stock you will need to have a chip, and pretty much same goes for the TB. The computer is set to work with stock equipment, and it won't run properly if you don't have a chip burned to change those parameters to what you install. You'd also have to consider a new cold air induction. As far as size goes, it's up to you, but you'd probably have to go with bigger injectors, and fuel pump as well, and consider a descent exhaust system. To be honest, I'm not sure what a 2.7 pulley is, normally we use either a 5 or 10%
common sense...
so rare,
it's kind of like
a super power
SuperCoupe is offline
post #3 of 4 (permalink) Old 08-08-2014, 07:59 PM
Moderator & Teksid Whore
guitar maestro's Avatar
It simply depends on your anticipated power level. As was said you'll need a chip to avoid problems with the load calculation done by the pcm.
guitar maestro is offline
post #4 of 4 (permalink) Old 08-08-2014, 10:59 PM
Jimmy 2Coupes's Avatar
You don’t need a chip to run an aftermarket TB on an SC.
1995 SC (five speed)
Best E.T. [email protected]
Best MPH [email protected]
Best 60' 1.7489
1994 SC (automatic) [email protected]
On a stock long block with bolt on's
Sweet SC, lower13's coming.
Jimmy 2Coupes is offline
