Looking for an A/C bypass pulley - TCCoA Forums
post #1 of 15 (permalink) Old 02-18-2016, 12:13 PM Thread Starter
Matt_aka_Dale's Avatar
Last time I was on Summit's website, I believe they gave me three options, but not sure which works. Dorman 34184, 34164, and 34151say they are for my 3.8l, but 34164 has a different bracket, so I can rule out that one
Matt_aka_Dale is offline
post #2 of 15 (permalink) Old 02-18-2016, 05:41 PM
nickleman60's Avatar
If you want to remove the compressor for good you can route it like I did, it'll take a new serpentine belt tensioner from an n/a V6 Mustang and a different length belt.
Change ac delete
N/A V6 Mustang/Tbird tensioner
NAPA 25-08560 8 rib belt
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #3 of 15 (permalink) Old 02-18-2016, 08:07 PM Thread Starter
Well to be honest, whichever way is the most effective, that's the way I'd like to go. Considering earlier today I damaged the compresser, I would rather not buy another one.
post #4 of 15 (permalink) Old 02-19-2016, 12:55 AM
ikutoisahobo's Avatar
A new compressor kit is only 140 bucks for the whole kit, seals, compressor, orifice tube, and accumulator/drier. The compressor stand-alone with no other AC components is only a 100 bucks. If your reason for deleting the AC is money then just know it's pretty cheap.
ikutoisahobo is offline
post #5 of 15 (permalink) Old 02-19-2016, 09:12 PM Thread Starter
Which tensioner is being replaced with the Mustang tension?
post #6 of 15 (permalink) Old 02-20-2016, 07:41 AM
If you plan on repairing and keeping the a/c then an a/c delete pulley is the way to go. If you don't then go the route that I did then can remove the compressor and condenser that's in front of the radiator so that more air is able to go directly through your radiator thus better cooling.
post #7 of 15 (permalink) Old 02-20-2016, 07:43 AM
If you plan on repairing and keeping the a/c then an a/c delete pulley is the way to go. If you don't then go the route that I did then you can remove the compressor and condenser that's in front of the radiator so that more air is able to go directly through your radiator thus better cooling.
post #8 of 15 (permalink) Old 02-22-2016, 08:16 PM
MAMN12 Posse Member
JeffTBird93's Avatar
I did the full delete from mine. It's the best way to go since it completely removes all the a/c hardware from the car. Use the n/a tensioner, an 8-rib pulley, and the shorter belt. You'll also need 2 washers to sit behind the pulley on the tensioner to get proper alignment on the belt. Really cleans the engine bay up. Part numbers can be found over on SCCOA. If you want, I have the belt you need I'd sell you for $15 shipped.
~Jeff
*signed off
JeffTBird93 is offline
post #9 of 15 (permalink) Old 02-23-2016, 12:13 AM Thread Starter
Just random washers or specific sizes? And what overdrive pulleys are needed?
post #10 of 15 (permalink) Old 02-23-2016, 05:49 PM
MAMN12 Posse Member
I used two 5/8" stainless steel washers (got them at Lowes). The only pulley you need is Dayco 89053 8 rib pulley on rockauto.com. Put it all together, and put it on the car. I also drilled out one of the holes on the engine bracket to allow the bigger mounting pin from the tensioner.
~Jeff
*signed off
post #11 of 15 (permalink) Old 02-23-2016, 08:53 PM Thread Starter
Found the pulley and tensioner. Just need the shorter belt
post #12 of 15 (permalink) Old 02-24-2016, 07:19 PM
MAMN12 Posse Member
Got a brand new one...$15 shipped to your door.
~Jeff
*signed off
post #13 of 15 (permalink) Old 02-26-2016, 09:57 AM
jco1385's Avatar
I'm looking to buy a kit for mine. Where can I find it for $140?
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #14 of 15 (permalink) Old 02-29-2016, 01:19 AM
RockAuto has the compressor kits.
post #15 of 15 (permalink) Old 03-07-2016, 08:15 PM Thread Starter
Progress. Now waiting for the 8 rib pulley.
