jb weld to repair gas tank - TCCoA Forums
post #1 of 7 (permalink) Old 04-16-2003, 11:54 PM Thread Starter
Talking jb weld to repair gas tank
I was wondering has anyone tryed jb weld steel to repair loose solder joints on gas tank. I was thinking of doing this when that time comes around. beats the hell out of welding.
Wayne Murray is offline
post #2 of 7 (permalink) Old 04-17-2003, 10:26 AM
Umm.....our gas tanks are plastic.
post #3 of 7 (permalink) Old 04-17-2003, 06:47 PM
NO, welding could cause the fuel to explode anyway! . . .I know, JB weld.
talon660 is offline
post #4 of 7 (permalink) Old 04-18-2003, 07:07 PM Thread Starter
Welding a empty gas tank is not a safe fix , what I 'd like to know is what is the procedure for a gas tank repair if the lines or should I say fitting become detached from the tank? Some posts say that they must be re-soldered to the tank. I suppose one would use a soldering Iron to complete this repair. But now I am hearing that the fuel tank is plastic, what is the deal.
post #5 of 7 (permalink) Old 04-18-2003, 07:37 PM Thread Starter
Smile
After looking at the fuel pump repair how to, on mn12 performance bbs the picture is clear. A fuel pump upgrade is definitly in my future,will solve my phantom gas fume problems of not so long ago. Hence gas tank repaired.:tongue
post #6 of 7 (permalink) Old 04-22-2003, 09:20 PM
Maybe your fuel vapor canister is bad, meaning having fuel in it. Its located in the pass fender just behind the bumper. Good luck
vancouverBC is offline
post #7 of 7 (permalink) Old 05-01-2003, 11:37 AM Thread Starter
Smile
Thanks, Vancouver BC I will definetly check the vapor canister.
