found a easier way to get the nut off to change the pulley on the eaton m90 sc - TCCoA Forums
post #1 of 2 (permalink) Old 05-08-2003, 08:51 PM Thread Starter
On Probation
blown96bird's Avatar
I am changing the pulley on my allen supercharger. My stock pulley dose not give enough boost after the mods the boost droped 25% from 7 to 5 psi. I decided to add a smaller pulley to get the torque back up and more hp. I had a bad time getting the nut off the supercharger nose because not being able to keep it from turning. I noticed the nut on it was 18 mm and the hex nut on the pulley was 1 1/8 inches then I had the ideal to buy a 1 1/8 12 point deep socket and grind a couple of the edges so that it coudl be held by a 1 1/4 wrench and stick a 3/8 drive socket the opening.to the 18 mm unit. I used a 1 1/4 inch wrench to hold the socket and keep the nose from turning and used a 3/8 drive breakerbar to break the nut loose. It also works great on installing the nut
blown96bird is offline
post #2 of 2 (permalink) Old 05-08-2003, 09:56 PM
AED Specialist
A-Train's Avatar
Talking
Steve,
I'm thrilled you dropped the other plan of attack.
Now get yourself some respectable numbers and keep us posted.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
