EGR codes - TCCoA Forums
post #1 of 4 (permalink) Old 06-05-2018, 11:50 AM Thread Starter
nckhammond's Avatar
EGR codes
When I do a code scan I get pretty much every EGR code there is. Anyone see any harm in ignoring the EGR until winter when I pull the engine apart to replace gaskets and probably just delete the EGR alltogether. (I dont live in an emissions teating area)
95 Thunder Bird SC Auto Daily Driver Work in Progress, with every factory option original owner could check.
nckhammond is offline
post #2 of 4 (permalink) Old 06-05-2018, 02:36 PM
dDUBb's Avatar
Its mostly for fuel economy, so no harm ignoring the codes as long as you don't have any vacuum leaks causing the EGR to be inoperable.
dDUBb is offline
post #3 of 4 (permalink) Old 06-07-2018, 01:31 PM
There are seven pieces of tubing in that line; all are bad now.
EDIT: No, that's for the 4.6l. But I'm sure that's the problem.
post #4 of 4 (permalink) Old 07-12-2018, 04:04 PM
bowez's Avatar
My SC has no EGR, been deleted. I also temporally blocked off the EGR on my F150 (300), it ran better than leaking but I did replace and return to stock.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
