Oil pan replacement - TCCoA Forums
post #1 of 14 (permalink) Old 05-27-2003, 06:09 PM Thread Starter
Oil pan replacement
My oil pan needs to be replaced. Long story, got cracked because my neighbor chewed up the dirt road I live on, he's paying for the repair.
Does that involve lifting the engine? The guy at the shop thought it might, and if it does then I want to do motor mounts at the same time.
Are there any other good things to do while the shop is replacing the pan?
SC Roach is offline
post #2 of 14 (permalink) Old 05-29-2003, 12:09 AM
Yes, to replace the pan you either have to lift the engine or drop the subrame.
Personally, if a guy in a shop doesn't know if you have to move the motor or subframe then I'd go to another shop.....I can't think of many vehicles that allow you to change the pan without doing any major work.
yyc_tbird_sc is offline
post #3 of 14 (permalink) Old 05-29-2003, 07:33 AM Thread Starter
actually, it was more me that was unsure than him. It's a good shop.
I ordered the motor mounts, so hopefully a smoother ride is in store for me; in addition I am getting new shocks in a month or so
SC Roach is offline
post #4 of 14 (permalink) Old 05-29-2003, 12:32 PM
How much did the motor mounts cost ya? Are they stock replacement?
You own an SC yet you live on a dirt road! How dare you!
talon660 is offline
post #5 of 14 (permalink) Old 05-29-2003, 12:40 PM Thread Starter
The mounts ARE NOT stock replacements, they are solid rubber, like the mn12performance ones but not from them. I got them from paul at blue tongue motorsports for less than mn12.
So yeah, my neighborhood road turns into dirt a half mile from the main road, when there are 2 more houses on it, then my driveway is pavement again.
It's a quarter mile of dirt road. eh
SC Roach is offline
post #6 of 14 (permalink) Old 05-29-2003, 01:24 PM
They are not listed on the website, I guess you talked to him personally or they are not posted yet. How much less if you don't mind me asking?
talon660 is offline
post #7 of 14 (permalink) Old 05-29-2003, 01:50 PM Thread Starter
Paul is a good guy, I talked to him personally to get these... and he reccomended the Bilsteins instead of the Tokico replacement shocks.
www.bluetonguemotorsports.com
just a little bit less than mn12, he's always competitive.
SC Roach is offline
post #8 of 14 (permalink) Old 05-29-2003, 03:54 PM
I think there is a bolt under the oil pump through the front cover and into the oil pan as well. You definately need to remove the pump and you may need to pull apart a large portion of the front of the motor to get at it.
Big job.......Have fun.
SCrazy is offline
post #9 of 14 (permalink) Old 06-10-2003, 10:29 AM
No need to remove front cover or oil pump. As you can see in these pictures, all bolts may be taken out of the oil pan with those parts left on:
gldiii is offline
post #10 of 14 (permalink) Old 06-10-2003, 10:43 AM Thread Starter
to get the car inspected and back on the road, it needed
motor mounts (the old passenger side one fell out when they supported the engine and took the weight off of the old one)
oil pan (cracked from contacting the frame, caused by the bump and broken motor mounts)
rear tires (too worn for inspection)
front bushings (not sure why, just worn out, needed for inspection)
new bolt on drivetrain (they thought I needed new U joints but no)
finally getting the car back today after almost 3 weeks.
SC Roach is offline
post #11 of 14 (permalink) Old 06-10-2003, 10:48 AM
Thanks George for stepping in I noticed last night that the front cover bolt misses the oil pan as well.
What a pisser it would have been to pull all that crap only to find out you didn't need to.
SCrazy is offline
post #12 of 14 (permalink) Old 06-10-2003, 11:16 AM
There are two bolts for the pan that go into the front cover. I know several people have cracked the lower edges of the cover by not removing one of these bolts and trying to pry off the cover! One is very hard to see. Now that would really "torque" you off big time!
gldiii is offline
post #13 of 14 (permalink) Old 06-11-2003, 10:12 PM
George....in those pics, is that stud girdle custom? Does it all fit into the oil pan without too many modifications? And.....where can I get one?
post #14 of 14 (permalink) Old 06-12-2003, 11:44 AM
It's a Coy Miller piece. (http://www.coymiller.com/) It was installed with my Stage II motor. As far as I know, it only requires mods to the end of the dipstick tube.
gldiii is offline
