removing engine - TCCoA Forums
post #1 of 3 (permalink) Old 05-27-2003, 07:09 PM Thread Starter
removing engine
i've been looking everywhere and i can't find any how-to's for removing a 3.8 sc engine. what all do i need to disconnect? is it as simple as taking out all the bolts i can find attaching the engine to the car and lifting with a hoist or what?
ChrisBannon84 is offline
post #2 of 3 (permalink) Old 05-29-2003, 11:29 PM
check out this thread on the sccoa board:
http://www.sccoa.com/forums/showthre...threadid=24621
I put up the check list I used to pull mine a couple days ago.
While you have it out, might want to think about degreasing the entire engine compartment. I did mine today and got (almost literally) a ton of grease. Also, I found out the stock power steering rack in silver in color.....not the black that I originally thought it was. It all looked black before I started cleaning. After....well let's put it this way.... I'll be replacing all the loom on the hoses and wires before the motor goes back in.
yyc_tbird_sc is offline
post #3 of 3 (permalink) Old 05-31-2003, 01:01 AM
never mind....just realized that was your post I replied to on the SCCOA board. Have fun and good luck pulling your engine!
