opinions?? - TCCoA Forums
post #1 of 9 (permalink) Old 07-02-2003, 01:36 AM Thread Starter
opinions??
ok ive got about 100$ to make my car better. i have a 90 cougar xr7 im thinking of getting the overdrive pulley for the blower . however my car has 94000 mi on the origional head gaskets. is this a bad idea the exahaust is modded by i have removed the mufflers completely. i plan on removing the cats too. should i remove the cats before the pulley or should i not worry about it??
90cat is offline
post #2 of 9 (permalink) Old 07-02-2003, 05:04 PM
I would advise against anything bigger than a 5% because you are getting to the mileage where head gaskets might become an issue. I think you might actually get a better bang for the buck with a bigger TB if you could save a couple more $.
Just my $.02
ripvanbl is offline
post #3 of 9 (permalink) Old 07-02-2003, 11:42 PM Thread Starter
so a 70mm tb would give me more power than more boost?
90cat is offline
post #4 of 9 (permalink) Old 07-03-2003, 12:10 AM
you didnt really solve anything by removing the mufflers. the pinch on the outlet of the resonator is really bad as well as the downtubes. i wouldnt put the od pulley on the car unless you actually opened up the exhaust. you could get the tb but it is more than what you want to spend.
bagged90SC is offline
post #5 of 9 (permalink) Old 07-03-2003, 01:10 AM
Jimmy 2Coupes's Avatar
Wink
Your best bang for the buck for the money your talking is underdrive pulley's.
1995 SC (five speed)
Best E.T. [email protected]
Best MPH [email protected]
Best 60' 1.7489
1994 SC (automatic) [email protected]
On a stock long block with bolt on's
Sweet SC, lower13's coming.
Jimmy 2Coupes is offline
post #6 of 9 (permalink) Old 07-04-2003, 04:45 PM
Formula 1 Freak
SuperCoupe's Avatar
Thumbs down
Personally I wouldn't do any kind of intake upgrades with the stock pipes on the car, unless you wanna be replacing those head gaskets. That said, I've heard of guys with a 10% pully and a few other toys on the intake while running a total stock exhaust with no problems...(so far). Install at your own risk, just don't be too bummed if you end up doing head gaskets.
-Jeff
SuperCoupe is offline
post #7 of 9 (permalink) Old 07-07-2003, 08:08 AM
-Jeff
DITTO!!!!
Calvin
FearThis SC is offline
post #8 of 9 (permalink) Old 07-07-2003, 08:18 AM
Could blow the money on a partial tune-up? Magnacore wires, new spark plugs, etc...
JJanney is offline
post #9 of 9 (permalink) Old 07-10-2003, 12:41 AM Thread Starter
Angry
just got new wires and plugs , coolant, fuel filter,belts etc
im just starting to improve performance. saddly 2 days ago my 3rd gear clutch pack went so i dont have the cash anymore 700$ for a rebuild
90cat is offline
